Question about Mtd 25B-520D200 CA Gas Lawn Edger
How to replace a pull cord on mtd lawn edger - Mtd 25B-520D200 CA Gas Lawn Edger
  • 40 Answers
SOURCE: broken starter cord MTD Model 125-478R062
try this link.
http://www.smallenginesuppliers.com/shop/html/broken_starter_rope.html
you will want use size #4 or 4.5 starter rope. about 7 foot in length.
Posted on Mar 18, 2009
SOURCE: I have a Yard machine by MTD, Model # zr700r.
You nnnd to un-screw the srews that attach the housing to the engine. There will be 4 more srews to un-screw to get to the cord
Posted on Aug 04, 2009
  • 1206 Answers
SOURCE: I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Posted on Apr 26, 2010
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a 2 year old push mtd lawn mower , it wont ...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 24, 2010
How do i change the oil to my mtd 3.5 hp gas edger?
the fastest way to change the oil is to tip it on its side and drain nit threw the dip stick hole run it out of gas first if possible
Apr 07, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
My edger tipped over briefly, now the starter cord is hard to pull and it won't start.
Try removing the spark plug and squirting some carb cleaner or starting fluid in the cylinder. Pull the starter cord several times for the piston to drive out the oil. Clean the plug and replace it. Try to start as normal. If you have starting fluid squirt a shot in the air cleaner to help make it easier to start the first time.
Nov 25, 2011 | Mtd 25B-520D200 CA Gas Lawn Edger
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
Need to replce cord
Hi
The instructions in the following link refer to lawn mower but in my experience the mechnisim is the same :
http://www.cockeyed.com/lessons/mower/mower01.shtml
hope I helped you
Have a great day
Jul 19, 2009 | Mtd 25B-520D200 CA Gas Lawn Edger
Mtd 25B-520D200 CA Gas Lawn Edger Logo
83 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
