Question about Hayward Sand Filter System & Tank 21" 1 1/2 Hp
Where dothe hoses go - Hayward Sand Filter System & Tank 21" 1 1/2 Hp
  • 8,404 Answers
Suction from the pool goes into the front of the pump housing ... Discharge from the pump goes to the filter. If multi-port, there is a suction and a discharge port identified. If it is push/pull, Top port goes to waste, center is water in, bottom is water return to the pool.
Pool water is suppose to go into the top of the filter and out the bottom for return to the pool.
When manipulating the valfe (multi-port or push pull), ASSURE the pump is OFF! If multi-port valve, only turn the handle clock-wise.
Posted on May 16, 2010
How do you change the #3 spark plug on an 01 Blazer?
This is the one behind the steering shaft on the driverside, a swivel sparkplug socket and a small extension and a small peice of rubber hose, you will use the swivel to get loose then use the hose to slide on the plug and remove it by hand the rest of the way, to install you will dothe same, use a small peice of hose, slide onto the plug and tighten by hand as far as you can, then sldie swivel on and tighten, make sure not to over tighten, they dont need to be so tight, and make sure not to crack the plug, have soket as straight as it can go. its not to bad to do, ive found that getting the plugs through the wheel well is so much faster then from inside the engine compartment. hope this is helpful. good day.
Sep 03, 2011 | 2001 Chevrolet Blazer
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
Theres a yellow circle with 3 black doths on each side what dose that mean, is there a problem with my car
The brakes pads are worn. The brake pads and brake sensor, probably the front brakes, need to be replaced.
Oct 01, 2010 | 2004 Mini Cooper
The back liftgate does not open even though it is unlocked. I lift the open handle at dothing happens.
I had the same thing on my 96 GC. Turned out the latch and striker were rusted together.
Dec 08, 2009 | 1996 Jeep Grand Cherokee
What do i need to take off to get to the radiator drain plug?
On some there is a separate square in the front grille (passenger side lower corner) on some the grille itself needs to come out. On a great many of these, once you get to the drain you will find that it is clogged or frozen. When draining, it is far easier and faster to just remove the lower hose from the radiator. Just don't do it when hot, as the antifreeze comes out very quickly.
Dec 03, 2009 | 1995 Jeep Grand Cherokee
How to make code free
I call Marantz support and he told me it doth go
Nov 16, 2009 | Marantz BD7004 Blu-Ray Player
Top loader washer wtw6400sw3 will not finish drasining. beeping and flashing Ld
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies. Can I hear an Amen?
Aug 10, 2009 | Whirlpool WTW6400SW Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Hayward Sand Filter System & Tank 21" 1 1/2 Hp Logo
76 people viewed this question
Top Hayward Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hayward Garden Expert? Answer questions, earn points and help others
