Question about Microsoft Xbox 360 Controller
The light on wireless360 controller wont stop blinking batteries are good what else can i do
  • 31 Answers
Try installing the drivers manually from microsoft's website
Posted on May 31, 2010
I have a merits p313 electric wheelchair stop working put in new batterys the controler lights all blinking then just middle yellow blinking
have lights so not fuse blown
not much to these ..batteries .. controller .. electric motors
hard to mix up the positive and neg terminals
that is a two battery unit
check if the joystick controller or its cable is faulty
Jun 24, 2016 | Electric Health & Beauty
Light wont stop flashing
Light flasher will not stop flashing.
Jan 13, 2014 | RCA Televison & Video
Manta quadcopter won't recognize the remote
Turn on the remote controller first then heli the instructions are wrong
Dec 24, 2013 | Protocol Manta 4-Channel Radio-Controlled...
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Wont go forward
Check to make sure your brake freewheel is engaged in the DRIVE position and that your batteries are fully charged. If you have blinking lights on the controller, that may indicate another problem; check this website if you have blinking lights:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 08, 2010 | Health & Beauty
No forward, only backward
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
Jul 17, 2010 | Pride Mobility Products Hurricane PMV...
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
Wont start, security light keeps blinking
Turn the ignition switch to the on position and let the light blink. It should stop in about 10-20 minutes. then you can start the engine. if the light does not stop blinking likely the key switch is bad or, (less likely the module). Make sure your battery is in good condition when doing this or it wii kill the battery before the coding is complete (use a jumper to a good battery if necessary but don't turn the other vehicle on)
Oct 13, 2009 | 2003 Pontiac Grand Am
All lights blink but remote wont work
You may need to resync with your console. Take the battery cover off, and open the little door between the eject and reset buttons on the front of your console.
With the machine started and running, press the red button in your wiimote, then quickly press the same color button in the panel on the console.
Apr 16, 2009 | Nintendo Wii Remote Controller
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Jun 30, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Microsoft Xbox 360 Controller Logo
315 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
