Question about Polaroid FLM-3734B 37 in. LCD HDTV
TV won't turn on until it has been unplugged
Everytime we turn on the tv we have to unplug it and plug it back in. When it does turn on there is a loud buzzing noise, that goes away after a minute.
    President:
  • 1,099 Answers
Hello, If you can turn it back on with the momentary key or power button If once, then the controller is shutting the TV down either as a result of a (thermally induced) fault in the controller or it sensing some other problem. Monitoring the voltage on the relay coil (assuming these is one) could help determine what is happening. The controller thinks it is in charge.
If twice, then the power supply is shutting down as the controller still thinks it is on and you are resetting it. A couple of possibilities here would be low voltage or high voltage regulation error (excessive high voltage is sensed and causes shutdown to prevent dangerous X-ray emission). A partially dried up main filter capacitor could also cause a shutdown but there might be other symptoms like hum bars in the picture just before this happened. Clipping a good capacitor across the suspect (with power off!) would confirm or eliminate this possibility.
If it uses a pull-knob (or other hard on/off switch), then this may be like pulling the plug and would reset any abnormal condition. This procedures require a skilled technician to do this and require opening the back cover of the television.
Posted on May 16, 2010
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
TV won't come back after pushing wrong button on remote.
Try unplugging the TV.. After you plug it back in it may be OK. I had a similar problem were I could not turn on the TV (JVC). The owners manual specified in the troubleshooting section to unplug for 1/2 hour. I left it unplugged overnight and the next day plugged it in and it was fine.
May 21, 2013 | Televison & Video
Push the power button. stays on long enough to say digital and turns off.its not the inverter board.
I am currently working on the same problem. There is a simple test you can do to determin for sure that it is not one of the six inverts. Unplug them all. Plug each one in one at a time. Unplug from wall everytime. The tv will backlight even off just one. The tv is turning off due to a safety/protection feature. Once it senses the high voltage the tv will shut off. If you plug one in and the back light will not come on anymore you can fix your tv for $16. Pn/ 3pc0xB001
Oct 29, 2012 | Emerson LC320EM8 32 in. LCD TV
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Everytime I turn on the tv the closed caption is on
turn close caption off turn off tv, unplug tv and plug back in
Nov 13, 2009 | Philips Magnavox 42MF521D/37 Television
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Panasonic Home Theater won' play sound from TV
plug evey thing back how it was befor u unpluged the components to consolidate wall outputs.
May 11, 2008 | Panasonic Home Theater System System
Polaroid FLM-3734B 37 in. LCD HDTV Logo
234 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
