Question about Frigidaire Over-the-Range Microwave
Resetting the microwave the microwave all the
Resetting the microwave the microwave all the lights are on the display, but i can't set the time or turn it on.
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hi. I pressed the 'quickstart' button on my micromat 900 w microwave and used it for 10 seconds. On pressing the 'door open' button, the display panel is showing '1' rather than the cooking time or the...
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Sep 28, 2008 | AEG Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Sharp R510AK Carousel Microwave
Very common problem with the display. It may or may not eventually light back up on it's own.
I would suggest contacting www.microwavedisplay.com. Lots of info and the best deal going for repairing the display.
Jul 03, 2008 | Sharp R-510HW Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Frigidaire Over-the-Range Microwave Logo
35 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
