Question about Keurig B60 Coffee Maker
Filled with water and the screen says not ready add water
    President:
  • 1,099 Answers
Hello, This will require an opening of the coffee maker appliance, the themostat could be the problem because the themostat send current to the element of the coffee maker. Try to check the element and also check the fuse of the coffee maker.....
Posted on May 16, 2010
How to add antifreeze 2002 dodge intrepid
Open the container of antifreeze. Using a separate EMPTY gallon-size container, pour out HALF of the contents into the empty container, making sure not to spill any. Now, FILL the newly filled container with tap water. Fill the rest of the antifreeze with water, also. Now, you are ready to add antifreeze to your vehicle! Simply locate the radiator cap, (Don't touch it if it's hot!!) and unscrew it. Pour the desired amount of your mixed antifreeze into the radiator. Remember not to do this without proper knowledge!
Jun 26, 2016 | Dodge Cars & Trucks
Steam cleaner sc20
It works like a squirt gun, submerge complete unit into water to add water. After it fills pull out and ready to use.
Jul 28, 2014 | Conair SC20 Handheld Steam Cleaner
Maytag bravos doesn't use enough water
see this causes and fix it.
God bless you
Water comes in very slow This is usually a water valve problem or an inlet screen blocked. 1st check your inlet screens of your water valve. Turn your house water valve off to the washer, undo the fill hoses and inside the water valve, you will see a silver screen. If the screen is filled with water deposits, clean it out and re-install into valve. Don't forget to check your fill hoses also, some hoses come with screens that also may be clogged. Your cold water valve usually clogs before the hot water valve, all that sediment settles in your hot water tank and not in the screens. If you are on a well system, your screens usually clog more often. If your screens are good, then most likely your water valve needs replacing.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
How to descale a breville one cup
NOTE: Not my instructions i just found something similar.
According to the instructions for Breville Hot Cup (presumably similar to yours - the adjustable flow one):
1. Fill it to the max and dispense one cup of water.
2. Add a citric based descaling product into the cup and stir.
3. Tip contents into kettle and close lid.
4. Dispense water from the kettle, discarding the water until it reaches the 'min' mark.
5. Empty remaining water into sink, rinse out with clean water.
6. Fill kettle with fresh water and dispense cups of water until it reaches the 'min' mark. Empty the rest into the sink, then refill ready for use.
Nov 24, 2011 | Breville Coffee Makers & Espresso Machines
No water inputted in rinse cycle
Turn off the cold water valve supply to the washer and unscrew that hose off the back of the machine. Take the screen out from inside the washer where the hose was screwed onto. Clean out the screen and re-insert it. Re-attach hose, turn valve back on. Presto, better water fill rate.
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
The Bleach Cup
An overloaded machine.richardm69
Nov 23, 2008 | GE Profile WPRE6100G Top Load Washer
Add water
emty the water shake the machine in our hand the water float is probably stuck try it after use product that gonna get ride of calcium
Jan 16, 2008 | Keurig B100 Coffee Maker
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Keurig B60 Coffee Maker Logo
660 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
