Question about Kobe CH2230SQ Kitchen Hood
Where to buy the circle oil holder under fans for Kobe CH2230SQ?
  • orncsu08 May 16, 2010
    where to buy KOBE parts after two years KOBE warranty expires?
  • orncsu08 May 17, 2010
    Thank you all for your help. I will try.
  • 8,197 Answers
The only way to get parts for that hood is to contact KOBE on the link below.
http://www.koberangehoods.com/main/contactus.html
Posted on May 16, 2010
    President:
  • 4,070 Answers
Hi! Please click the link to guide you where to buy the parts. Hope this helps and have a good one! please click here http://www.thenaturalhome.com/ch122.htm
How do i remove the low beam bulb 2005 chevy cobalt
Under neath the bonnet look for the back of the front lights, there should be a round circle holder which you twist to the right or left and the whole light holder should pop out. Change the bulb and repeat the process you did before except to put back in the light holder and twist to tighten..
Nov 27, 2011 | Cars & Trucks
The electrical system shorted out when a light bulb broke while changing it. The circuit breaker did not trip. None of the electrical system works. Is there a fuse to replace? Do I need to replace the...
you need to replace the light fitting holder as this is the reason the system failed.As to why the circuit breaker failed that is a mater for an electricion,because i would suspect a majour fault on the home electrical system.adrian.
Mar 15, 2011 | Kobe IN2636SQB Stainless Steel 32" Kitchen...
My processor fan making noisy sound, how should i fix that?
if that is an intel processor fan, i suggest you to replace rather than fix that.
its cheaper buy a replacement than fix that.
Mar 08, 2011 | Intel Computers & Internet
Rocky has a tumbling (unbalanced) sensation when grinding you can feel and hear. Seems less if you back off grind # to 20 from 8. Been using 8 for a year with no problem before today.
  1. take the bell(bean container) carefully out.
  2. disassemble the upper holder of burr
  3. you will see now the burrs, clean good coffee remains than disassemble the burrs
  4. after disassembling burrs clean good the lower and upper burr holder.
  5. carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly,
  • if it is ok you will have complete circle
  • if it is deformed you will have incomplete circle( that you must compensate with letter tape )under the burrs you apply the letter tape
  • after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Aug 20, 2010 | Rancilio (RAROCKYND) Grinder
My existing duct is a 4x10, the KOBE CH2230SQ does provide the 4x10 ducting option, but 1. it does not have any spout to catch the duct opening; 2. the vent plate has a thickness, but my cabinet is...
You should be able to purchase the 4x10 hood boot from Lowe's or Home Depot. As for the cabinet mount, maybe you can cut a bigger hole. I have modified fittings to fit small spaces but most heat and air installers can make you fittings for small confined spaces. I have found them to be quite reasonable too! Hope this helps.
Aug 12, 2010 | Kobe CH2230SQ Kitchen Hood
How to stop squeaking noise
usually these units have very inexpensive sleeve bearings that require little maintenance. Have you tried squirting a little WD-40 on the bearings?
May 14, 2010 | Lakewood 200I Floor / Box Fan
I want to buy some oil to lubricate my hobart slicer .what to use
If you can, remoove the blade - very carefully. Clean everything where you can. It's a virtual trash holder under the blade. Where the blade mounts, you can use mineral oil to lubricate the bearing. If it makes any contact with food, it won't hurt you.
Dec 31, 2008 | Food Mixers
Installing on dashboard
Download the owner's manual here:
https://buy.garmin.com/shop/store/manual.jsp?product=010-00657-10&cID=134&pID=10624
Jul 07, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Control Panel Breaks Down
is your control panel is under the hood? if so, every time you use your stove turn the hood on, the reason is, the heat from the stove burner is melting it, but if you have your hood on, it will pull away some of the heat. you can try to put your hand at the control panel with the front burners on, then you will feel the heat from the stove.
Oct 16, 2007 | Kobe CH7936SQ Kitchen Hood
Kobe CH2230SQ Kitchen Hood Logo
Top Kobe Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kobe Kitchen Range Expert? Answer questions, earn points and help others
