Question about Roper Dryers
Hello my roper dryer stop working what can it be
  • Roper Master
  • 2,605 Answers
Hello, Welcome to Fixya. Does it turn on at all or turn on and not heat ? Based on your post "stopped working" I suspect it won't come on at all and therefore you have an open thermal fuse or busted door switch. To check the door switch, open the dryer door, and move it to the almost closed position ( enough to engage the switch but not latch the door ) listen closely for a "clicking" sound. If it clicks it is likely fine. To check the thermal fuse is a little more involved. You can do it with an ohm meter or without, I'll explain both ways...but **FIRST** Turn off the breaker or unplug the dryer. Now remove the rear panel by way of backing out the screws all around the large panel at the back. Once the panel is removed look for a small "white" fuse/thermal link with 2 wires ( usually blue ) attached to it on the blower housing. Take one wire off, place the leads of an ohm meter across the contacts to see if there is continuity ( the numbers or needle on the meter should move ). If there is no continuity, you need to replace the thermal fuse. To check it without a meter, make sure it is unplugged or the breaker is off...obviously very important. Remove both the wires from the fuse and join them together,( alligator clamps or jumper wire works best ) make sure they make good contact and rap them with electrical tape. Make sure no wires are touching anything, plug in the dryer and give it a try. Let me know how it goes and what you find. If you need further assistance I will be here. If this was indeed you problem, please take a moment and rate the solution provided here today and thank you for visiting fixya. Good luck. macmarkus :)
Posted on May 16, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Roper dryer will not start
How to Troubleshoot a Roper Dryer That Will Not Start ' Home Guides ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Jul 14, 2016 | Roper Dryers
Dryer just stopped working,i pushed the start button and nothing?
The number one reason a dryer will not start is because of a blown thermal fuse. This tip i wrote will help ya to check the thermal fuse. http://www1.fixya.com/support/r10530385-dryer_power_but_start
I hope this will help ya to fix your dryer,
GENE
Sep 23, 2011 | Roper REX4634KQ Electric Dryer
Where is roper thermal fuse, its an older dryer
On older Whirlpool brand dryers(roper is made by Whirlpool) the thermal fuse is usually always in the blower housing..to get to it ya would need to remove the back panel.
This video shows who to replace the thermal fuse http://www.youtube.com/watch?v=aUQQJAxkZ0g
GENE
Sep 16, 2011 | Roper RES7646KQ Electric Dryer
Roper dryer stopped working altogether,doesn't do anything
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 19, 2010 | Roper RES7646KQ Electric Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
Have a Roper gas dryer and there is no heat coming from it.
If you try it again tomorrow and it works at first but quits again then you need to replace the coils. I have repair photos HERE
Bonus HERE
Jan 15, 2010 | Roper REK2950W Electric Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Roper Dryer
You may have tried this but every time mine has ever stopped and refused to restart was because I forgot to clean out the lint in dryer screen.
Jun 29, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
151 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
