Question about Amcor Processor 2000 Air Purifier
Where can i purchase filters for amcor ionizer 2000?
Need new filters
You may need to order the filters directly from Amcor unless you can find a local source
May 02, 2013 | Air Purifiers
I need a filter for Amcor Ficus Tree Air purifier
If the activated charcoal filter, take your old one apart and trim down a larger on from a competitve machine to fit yours. The same if it is a HEPA filter you want to change as well.
Otherwise metal and plastic filters can be washed. Spray with a grease cutter like 409, which will also lightly etch the metal without reacting with the plastic.
Jan 31, 2012 | Amcor Ficus Tree Air Purifier & Ionizer...
We purchased this at a thrift store. Can you tell me what the ionizer setting is for
The ionizer cleans the air. If it's working properly, it will smell like the air right after a lightning storm. You should use as little as possible, based on the size of the area, you're using the unit in. Do not allow it to blow directly on you or anyone else. The higher you can place the unit, the better it will work. Match the fan speed to ionizer setting.
Hope this helped you.
Jul 09, 2011 | Duracraft Air Purifiers
How do I clean the ionizer when the check filter light turns on?
with no power to the unit take a soft moist cloth and wipe easy all the wires are flat plates
Apr 14, 2010 | Brookstone Ionizer/ Air Purifier Air...
XL-15 Classic Living Air emmitting Foul Odor!!
Ionizers do cause a bad odor to happen. I work in the copier business and do work around machines that can cause an ozone to happen when there are ran. Copiers like ionizers can cause an ozone to happen because the air particles are being electrically charged. The smell isn't good to be breathing in as well.
Here is an EPA report about ionizers
The Consumer Products Safety Commission is going to be making a decision about the health effects on ionizers by the end of the year. Their decision can effect selling ionizers all together.
This industry should have been regulated years ago and after what happened to Sharper Image this year due to their arrogance it isn't doing the industry any favors. They went out of business because of Consumer Reports findings and tried to sue them for it.
If you really want the air in your house cleaned, the best way to do it is using a hepa filter.
Jul 26, 2008 | Ecoquest Living Air Classic Air Purifier
Class action lawsuit
Not only that but even the EPA has said that ionizers are bad for filtering the air to begin with and that the report has been out there for several years.
Here it is from the EPA
The Consumer Product Safety Commission is going to make a report on all ionizers by the end of the year. It is possible that they will no longer be sold in the US forcing others such as Orcek into some financial trouble.
Jul 26, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze GP Sharper Image
Sharper Image ionizers are no longer being serviced. What got them into trouble in the first place was the fact that they were not cleaning the air and that the air they were filtering was hazardous some peoples health. This was based on data by Consumer Reports as well as the EPA. They went to court on it and they lost.
Sharper Image was offering a rebate to people who had purchased ionizers.
The Consumer Products Safety Commission is going to be making a decision on ionizers by the end of the year. It could be that they will no longer be sold in the US next year since they are ineffective and can cause health problems.
This is an industry that should have been regulated years ago just by EPA data alone. The idea that charging the air around you gets rid of stuff is a joke. In the copier industry that I work in we are told that it is bad since copiers create ozones in the same way.
Jul 22, 2008 | Sharper Image Professional Plus Ionic...
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Annoying ticking
My air purifier was doing the same thing. The ticking noise you are hearing is caused by dust build up on the ionizer pins. When the ionizer pins collect too much dust, they tend to start making the clicking/ticking sound caused by static electricity. The solution is simple. Take the filter out and clean it real good (follow directions on filter on how to clean). Now, with the filter out, if you look down inside the vent where the filter was, you'll see a white piece of plastic with nine holes in it that are about the size of a silver dollar. Directly in the center of each hole there will be something that looks like a needle, those are the ionizer pins and they will probably have dust built up on them. Next, with the filter out, blow out the air purifier with compressed air to clean all the dust off the ionizer pins. This should take care of the problem, it worked on mine.
Dec 02, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Amcor Processor 2000 Air Purifier Logo
292 people viewed this question
Top Amcor Air Purifiers Experts
Are you an Amcor Air Purifier Expert? Answer questions, earn points and help others
