Question about Maytag Neptune FAV6800AW Top Load Washer
Od error code
I have opened and closed the lid, unplugged the machine and it still has the same error code. Any other suggestions?
I've been fighting the same problem for 2 days in frustration I just dropped the lid and it started working
Posted on May 08, 2009
  • 96 Answers
If the error code still appears it means that the reed switch that senses if the lid is in the closed position is either jammed or faulty. You can try to temporarily bypass it and see what happens, but don't leave it in that condition. If necessary, have it replaced.
Posted on Apr 01, 2008
SOURCE:
My whirlpool duet is displaying the error code 888. It works ine through all cycles but the time displays 888. All the lights are illuminated and there is a high pitch alarm sound that remains on until...
Please state brand and model of your washing machine for accurate and specific solution...
There is no 888 error code on my list of whirlpool..I think the 888 flashes is the time remaining..
If the lid opens while the unit is in running mode, time remaining will flash in the display.
Close the lid and press START to continue with the cycle.
Hope it helps..
Dec 03, 2011 | Washing Machines
I have a top load machine which shows LE error code despite lid is closed properly. This continues for half an hour then machine starts working again but the error resumes after every two minutes. Plz help
'LE' stands for Lock/Lid Error. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
LS shows in the display; machine stops and doesn't respond to reset or to temporarily unplugging
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Du f flashes as code on whirlpooll whasher??
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code du
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Jul 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
L S or L5 error code on Calypso top load washer (Color - grey)
LS Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
WASHER CODE
You have a lid switch problem.
check for junk plugging up the area of the lid switch.
It needs to move both to the contact position(when door is closed)and to the non contact position(when door is open).
Also, the switch may be bad, or the wires going to it may have been cut by the drum because sometimes these wires are not fastened good enough and are able to contact the drum.
Anyway, the switch is just like turning a wall light switch on and off.
There may be an actuator on the door that presses against the switch, that could be missing(fallen off/broken off).
Feb 12, 2008 | Washing Machines
Whirlpool cabrio HE error code
The problem with this is the lid lock is broken i suggest replacement of the lid lock to solve your problem
Jan 14, 2008 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
242 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
