Yamaha r-v1105, push power button, hear it click, display shows for 1 split second, unit instantly shuts off. ?
  • 560 Answers
Looks like a bad micro-chip or grounded connection. Remove all speakers, if it powers on then we know that you have a grounded speaker somewhere. If it doesn't, check the board for any cause of grounds like dirt or strand of hair. Clean the board with cold air blower. If no improvement, send your receiver to an authorized service center to avoid further damage. The receiver may have a bad IC that needs replacement.
Posted on May 16, 2010
  • Liza Halbrook
    Liza Halbrook May 16, 2010
    Also, please check if the IMPEDANCE SELECTOR switch on the rear panel is correct.
Marantz SR5004 shuts off after a second or less
It's going into safe mode check the power supply
Feb 14, 2014 | Marantz Audio Players & Recorders
After a power outage my denon 2803 receiver will not turn on.
Hello. First unplug and replug in your receivers. When you push the power button, you should hear 1 click. Within 5 seconds, you should hear a second click. Can you please tell me the results?
Thank you.
Sep 15, 2012 | Denon AVR-2803 Receiver
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
When push the power button, I can hear a relay click but the unit will not power up. I took the cover off and fuses are good. Can't find anything in the trouble shooting section of the manual. What do you...
When the unit functions correctly, you should hear 2 clicks. The first is the power relay that "starts" the unit. The second is the speaker protection relay that will kick in the speaker connection. If you do not hear the second click, the unit is in protect mode. This means that a problem was detected in the amp section and the unit is prevented from connecting the speakers. This is done to prevent further damage. Typically the output transistors fail and cause this. Expect a parts cost in the $25-$50 range for this repair.
Dan
Sep 30, 2009 | Yamaha RX-V1500 Receiver
Lamp Timer Reset procedure Panasonic Projector PT-L759E
Greetings!
It's been a while since I did one of these, but if I remember correctly:
- Turn on the set
- Push volume down on remote and at the same time....
- Push Split on the remote and hold both for 5 seconds
This should do it. The display should reset to "0".
Rob
Jan 05, 2009 | Office Equipment & Supplies
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
Shuts itself off randomly
Go to the site http;//www.loadparts.com there got the ICs you need .
May 17, 2008 | Yamaha R-V1105 Receiver
R-V1105 Will not turn on
Change the audio amplifiers ICs because they are damaged,that's why your device protect himself from a bigger damage.Good luck.
Apr 18, 2008 | Yamaha R-V1105 Receiver
R-V1105 Yamaha receiver
Your audio amplifier ICs are damaged,you gotta change it.
Nov 17, 2007 | Yamaha R-V1105 Receiver
Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Nov 26, 2005 | Yamaha HTR-5150
Open Questions:
69 people viewed this question
 Grubhead
Grubhead
