Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
John Deere L120. When the mower clutch is engaged (switch pulled outward), the engine dies. Appears to be safety interlock related because the engine will recover if the PTO switch is returned to off.
    President:
  • 1,627 Answers
Try a new seat switch,or the rio switch on the right rear of the trans-axle.
Posted on May 17, 2010
John Deere L120 wiring diagram
The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
Aug 01, 2014 | John Deere L100 Series
Mower will not engage when switch for electric electric clutch is pulled up into on position
could be safety switches faulty or sticking,usally 1 under seat, and 1 by the catcher, pto toggle switch maybe faulty, if battery is low there won't be enough power for the clutch to engage. I would jump the clutch to make sure that hasn't died first cause that is the costly part.
Jan 24, 2011 | John Deere 195HP Hydrostatic 42" Cut...
I had just started cutting grass with my John Deere L120 riding mower when the blades stopped turning. I thought the belt had broke or come off so I pulled into my garage to investigate. I turned the mower...
You have several safety switches on your unit. The engine should not start if the PTO safety interlock is engaged. Be sure PTO switch is off.
If the sarter Does Not Work Or Will Not Turn Engine Brake pedal is not depressed.
or the PTO is engaged.
Battery terminals are corroded. or Fusible Link in starting circuit is blown - (Not likely unless bad wires) Here is a link to your wiring diagram (maybe your model)
http://www.postimage.org/image.php?v=Pq1tOfiS
Notice how the starting circuit goes through the brake pedal (must be depressed) and the PTO switch (must be disengaged) and that the PTO only works with operator present. Print that page while link still works.
Aug 11, 2010 | Garden
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Every time I lift off the seat of my John Deere engine Dies....
The seat switch is doing it's job,you can;t get off the seat unless the pta is off and the tractor has the park brake engaged.Replacing the switch won't change anything.
May 16, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
848 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
