Question about Kitchen Ranges
Large burner stopped working
The large Front left: Ultra rapid 4.0 kW burner has stopped working. It lights but has very low power/gas pressure. What could be wrong?
    President:
  • 1,314 Answers
First thing id do is check the knob to make sure the shafe isnt split and slipping if its good you will need tho change the valve
Posted on Mar 31, 2008
SOURCE:
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
My old garland gas range, model J38H0, has 3 problems. one of the large burners only burns low, even when fully turned up, the oven won't light at all, and the other large burner ignites at the air intake...
Most likely the igniter is no good and does'nt get hot enough 2 start the oven. Check and make sure their is no blockage to the burners sometimes they get loaded with food and or dust
Sep 03, 2017 | Garland H283 Gas Kitchen Range
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
Burner keeps going out
It might be the ODS Pilot Assembly. It could be clogged with dust or lint.
It might be low gas pressure.
It could also be the pressure regulator.
Oct 07, 2009 | Vanguard International Infra Red - Large...
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
