Question about Crosley CAR24CSS Thru-Wall/Window Air Conditioner
Lcd lights are on but tne fan motor does'nt come on
    President:
  • 1,796 Answers
Hi!!
If the indicator light is on, it means the board is sending the signal, first, check wiring for loose or disconnected terminals to the blower fan Relay, (welded on the circuit board), also, check Relay, you should hear a click everytime the fan button is pressed. If Relay is OK, check capacitor, with power disconnected from wall, discharge capacitor touching terminals w/screw driver, using a multimeter in the Farads function, touch both therminals and compare result with capacitor label. If capacitor is double, (three prongs) check between the one that says Fan and the one with the letter C. The terminal labeled Herm, is for the Compressor. On this type of capacitor it should have something like 5/35 uF + - 5%. the small number refers to the fan motor and the big number refers to the compressor, so the reading you should get should be 5 (+ - 5%) which means 4.75 min. - 5.25 max.
80% of the time. the source of this type of problem rests in the above mentioned components, I am pretty confident that is the source of your problem.
Don't forget to rate this post, Good Luck.
Posted on May 16, 2010
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Radiator fan does'nt work
The radiator fan circuit also has a relay and/or temperature switch, or it could have a temperature sensor,and the PCM turns the relay on and off to actuate the fan(haven't worked on a Ford from this era in a while).Relays do contain moving parts,so this is most likely the cause(use a test light to see if the relay is getting 12v,ground,a switched signal source,and that there is continuity to the fan connector).
Feb 24, 2012 | 1988 Ford Tempo
Dayton_furnace I have a dayton furnace the blow and burners kick on and run fine, brings the house up to the right temp the burnes shurt down but the fan moter never stops blowing. what is wrong ?
Hello, if you are referring to,the blower motor then most likely the relay on tne integrated contol board is malfunctioning. Unfortunatly the whole board must be replaced in this case.
Nov 09, 2011 | Dayton Heating & Cooling
An orange light apear's on the power bottom and a loud fan noise
hope you did'nt drop it but if you did'nt turn off unplug take cover off see if motor or fan is tight if it is could just use a good cleaning take a can of air they sell them everyware give it a good cleanning this should solve your issue.
Jul 28, 2011 | Dell OptiPlex SX280 PC Desktop
Tne fan continually makes a pulsating / grinding sound. How do I know if it is making the sound because it is out of balance or because there is a problem with the motor?
Try spinning the fan by hand. If the grinding sound is present, there may be something caught in the motor which is rubbing.
If the fan is out of balance, you may be able to see it vibrating or wiggling back and forth a little, especially at higher speeds.
Jul 15, 2011 | Encon Industries (78018) Ceiling Fan
The fan motor will stop working, but when I try to turn the fan blades, it turns pretty freely. When the unit is running for a few minutes, it trips the house breaker.
Hello, i would check the capacitor on tne unit, if it starts by turning by hand that means the capacitor is either weak, or bad.
May 09, 2011 | Whirlpool Heating & Cooling
I have a Pentair MiniMax NT heater. The fan does
if voltage to fan replace capacitor if no voltage check safety circuit
Aug 16, 2017 | Pentair Minimax NT Heater
KDS-R60XBR1 red light blinks four times when turning on
Replaced fan. Big one in the back p# 883586011 motor,dc sff21c/c-np. the four blinks indicate fan power is nt supplied (ASU board) , fan connector is loose, wires caught in fan ,fan stopped turning.
May 02, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
The light on my cooker hood comes on but motor dos,nt work it is a diplomat APP3440
It's probably a bad fan switch or a loose/corroded/broken electrical connector in the fan circuit. Another possibility (but not as likely) is the fan motor has failed.
Apr 21, 2009 | Imperial C2036PS1-TW Kitchen Hood
Crosley CAR24CSS Thru-Wall/Window Air Conditioner Logo
132 people viewed this question
Top Crosley Heating & Cooling Experts
ray gallant
Kiri Amarakoon
Level 1 Expert
Are you a Crosley Heating and Cooling Expert? Answer questions, earn points and help others
