Question about Kenmore 64742 Electric Dryer
Loud thumping noice - Kenmore 64742 Electric Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 16, 2010
Transmission not wanting to shift and a loud thumping noice under the hood..whats wrong I'm losing power
Could be several things but the most likely is a stretched drive chain inside the transfer case - not a job for an amateur. To change just the chain inside the box is a pig of a job, but getting the case out and back is a 5-6 hour job and requires a hoist and hydraulic engine/gearbox lifter
Jul 07, 2014 | 1998 Land Rover Range Rover
My Kenmore 3.6 cu. ft. High-Efficiency Top-Load Washer is making a very loud thumping noice what can it be and how can i fix it
The flexible joint under the tub needs to be replaced. This will require disassembly of the cabinet to access the joint
Jan 17, 2013 | Kenmore 24032\24036 Top Load Washer
My Performa Top Load Heavy duty (PAV1000AWW) has a loud noice when it is spinning. Just changed the belt but still extremely loud when spinning...any suggestions>
Thanks for choosing FixYa and welcome to the site. Anytime you have noise while spending, loud thumps and noises, it can almost always be traced back to the drive motor. This is what allows the washer to spin, drain, and agitate. You need to check this out first and check your spin bearing as well. I would say one or the other is the reason for your noise.
Apr 26, 2011 | Maytag Washing Machines
Hello, \r\nI have a 2003 dodge neon SE. I hear a loud roaring noice and vibration from the front end, the noise is really loud (like a truck) when I start it. When Car in drive the noice is loud but when I...
Hey Shona... Please take your car to a qualified professional... this could be something very serious related to safety.. do not take a chance.. let them diagnose your problem..please...
Jul 14, 2017 | 2003 Dodge Neon
1994 Oldsmobile Bravada - Driving - Loud Noices
Sounds like worn Constant Velocity Joints (CV Joint)
to me.
Feb 27, 2010 | 1994 Oldsmobile Bravada
My laptop is overheating and it is very loud when i turn it on and when it gets too hot it turns off
loud in the sense if ure talking about a loud noice contant beep noice it is your mic. go to sound setting s in control panel go to advanced and mute your mic. that shud take care of the loud noice. as of over heating it must ve been the coolant. u probably shud get it fixed or ull lose ur internal hardware. battery mit also be the problem
Dec 09, 2009 | Computers & Internet
Maks thumping noice
Replace the rear drum roller supports.
Jul 08, 2009 | Whirlpool Dryers
Charger makes loud whining noice
they have a cpu fan in it, and unlucky for you you cant buy anthother part, you either get a new one, or try sparaying some WD-40
May 02, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Kenmore 64742 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
