Question about Keurig B70 Coffee Maker
No water WHen brewing, soundslike pump is operating, but no water goes thru coffee
  • 560 Answers
The exit needle may be clogged. Please clean the exit needle, refer to Fig. 19, step 3.
Let me know if you need further assistance. Thank you for using FixYa.
Posted on May 16, 2010
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
Leaking water
If it's clean water which runs out, check the hoses going from the water tank to the pump then through the boiler to the brew group. If coffee is running out instead, then it's the spout going from the brew group to the cup. I know Saeco's not Juras but they all function the same way.
Mar 23, 2013 | Capresso Jura-13204 Impressa E9 Automatic...
I have a new B31 mini plus keurig brewer and I put the water/coffee in, hit the brew button, it flashes red then turns off after about 2 minutes without brewing the coffee.
MODEL B31: I made the mistake of not running water thru the machine first (the Initial cleaning) and was unable to get water to come thru to the K-cup. Reservoir was hot and full and would not come out. SOLUTION: I took a bendy-straw and completely covered the inside needle coming from the top (that goes into the K-cup) and pushed it up with a fair amount of pressure and blew hard into the straw. Then sucked on the straw (BE CAREFUL IF THE WATER IS HOT) and water and some coffee grounds came out. The brewer worked perfectly after this!!
Nov 27, 2010 | Keurig B30 Mini Coffee Maker
My keurig will not brew. It says it is brewing but the water level is not going down and it is not brewing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Nov 11, 2010 | Keurig B60 Coffee Maker
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Saeco Incanto - No water through the coffee brewer
Check the line where the water goes to the brew unit(be careful), disconnect and try to brew coffee, if water exits then the blockage is elsewhere, check the line where it goes into the white plastic valve behind brew unit, if water flows then check the brew unit make sure it is not blocked at the screen.
Jun 09, 2009 | Saeco Incanto Classic Espresso Machine
Think Pump or boiler broken as water doesn't flow through
If you cannot get hot water from machine(brew unit or steam valve), then there is something wrong with boiler elements.
If water won't flow thru coffee(pump is not vibrating) and you've tried adjusting the grind to a coarser setting, then you will have to replace the pump($50).
However, since no water is going thru machine and it does not heat up then the problem might be the board or the inline fuse on the machine.
May 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Not brewing
it sounds like the pump inside is bad, from either a clog or fuse perhaps.the pump sends the water thru so thats the likley problem.
Sep 13, 2007 | DeLonghi DCM485 Coffee Maker
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Keurig B70 Coffee Maker Logo
126 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
