3.0 ir dish network codes
My 3.0 IR Dish Network remote, won't program to my Zenith D56W25 TV, any help or codes out there? Please I'm lazy, and hate having to walk across the room to change the volume lol.....
6ya staff
SOURCE:
Anonymous
SOURCE: Need Remote Codes for Dish Network DVR
Durabrand tv's have three codes they are 623, 220, 221. one of those codes should fix your problem.
Posted on Apr 16, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: I have a Magnavox Model
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
Anonymous
  • 197 Answers
SOURCE: sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Posted on Jun 20, 2008
Jim Franks
  • 374 Answers
SOURCE: our dish network remote is
Due to the various remote types used by Dish for their different receiver types they may or may not have another receiver w/ a remote that would be compatible with your system. It also is a possibility that there is another remote that will operate your receiver and TV as well. you can check on Dishnetwork.com to find compatibility or you can provide me with the make and model of your tv and i will research it for you and let you know my results.
What you have right now is a half code situation with the remote. Their is no solution to this than the above or buying a universal remote capable of communicating with your receiver.
Hope this assists you and let me know if I can be of anymore help in the future.
Posted on Sep 08, 2008
Anonymous
SOURCE: Dish 20.0 IR Remote works for awhile then it
I MAY have a solution!! We too have the VIP722 Dish Network receiver. Ours is the "K" model. I called the place where we purchased the TV and they said that the "brightness" on the TV may need to be turned down. He walked me through this, and it worked. The remote WORKS now!! Our TV is a 40" Sony Bravia that we purchased a couple of months ago. Evidently at night, the TV was so bright in the room, it interfered with the Infared Remote control. By turning down "off" brightness detector on the TV, the IR remote was able to send the signal to the receiver. Our TV is on a cabinet and the receiver is directly underneath on a shelf. I hope this solves your problem and anyone else's that may have this problem with the remote.
Posted on Mar 18, 2009
I need to program a zenith tv to work with the 21.0 ir/uhf pro remote control
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at [email protected]!
Look up codes for TV here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Feb 14, 2014 | DISH Network ES161256 21.0 IR / UHF Pro...
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Codes and how to enter them for Panasonic Plasma tv for a Dish Network 1.5 IR Remote Control, model 113268
Hello Norma! My name is Becki, with DISH Network. I hope that you have gotten this resolved and your remote is working, but if not, here are some simple steps to program it! I hope this helps!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
700
685
689
Becki Barned
DISH Network Customer Service
[email protected]
Jul 30, 2011 | DISH Network IR Remote Control
NEED A CODE TO PROGRAM DISH NETWORK 5.4IR REMOTE TO OPERATE PHILIPS HTS3565D
Hello! My name is Becki, with DISH Network. Programming the remote to the TV is a pretty easy process. I have given some codes that should work to program the remote. If not, please let me know!
566
828
824
Becki Barned
[email protected]
Jul 13, 2011 | DISH Network IR Remote Control
Programar tv jvc con control remoto dish network
fidgar,
If I understand you correctly, you are having a problem with you DISH Network remote operating your JVC TV? What type remote do you have? If you look on the back at the top, you will see an 2 digit number; e.g. 3.0 ir. Please let me know what the model number is and I can provide you with code to try to program the remote to your TV.
Ray Calo
DISH Network
Jan 03, 2011 | DISH Network IR Remote Control
CODIGO ZENITH
garciaj9629
I'm not sure what type of problems you are having with remote. I have provided a link with instructions on programming the remote to the TV. I have also provided a link with the codes for different TVs. Look down the list for your TV brand. Step 6 is for programming the remote to a TV. I hope this helps.
Remote instructions:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Oct 08, 2010 | DISH Network IR Remote Control
I need codes to program my vizio sound bar to my dish remote
need 3-digit code to program Vixo sound bar to Dish Network 5.4 IR remote
Dec 16, 2009 | DISH Network IR Remote Control
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Nov 23, 2008 | DISH Network IR Remote Control
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Jul 11, 2008 | DISH Network IR Remote Control
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
