Question about Acer TravelMate 5530-5207 Notebook
Cannot create audio input (line-in) for creating a video on youtube.com. I select line-in for a microphne selection, plug it in on the front mic input channel on my acer, and nothing at all happens. I just for one second seen some kind of audio selection box pop up on the bottom right side of my laptop, but I made one selection, and it never reshowed again. I would use my webcam mic, but the volume blayback is very low. I'm trying to get more information and volume. Any advice? Just how do I create a line in that works? Thank you for any advice.
    Guru:
  • Acer Master
  • 1,705 Answers
Your Mic input is still probably the best to use, at a guess the only one.
Once connceted, go into your control panel, click on "Sounds and Audio devices" Under the "Volume" tab, Click on the "Advanced" box which is in the "Device Volume" box.
A new box will appear "Volume Control". If the Mike input is not include then click on options then properties and check the Microphone box.
The mike should now appear in your volume control box, ensure the volume is up and the "Mute" box at the bottom is not checked.
Posted on May 16, 2010
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
No audio video
NES AV to TV Hookup
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Jun 05, 2012 | Nintendo NES Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
Dec 27, 2011 | Nintendo Super NES Console
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Installation Steps:
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
My mic is not working even other sound device is working i need mic software for presario c700
Here's the step-by-step how you may solve this;
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
This will create a swsetup folder in C drive ("C:\sp36090")
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Hope this help.
Jan 27, 2010 | Compaq Presario 700 470024-192 Notebook
Mic not working
be sure that u have selected the correct input device in audio manager and u have plugged in a working mic properly...
if its still not working open ur input manager of ur audio device and select the input mode over der to a normal 1 not 5.1 channel then mic would work
Aug 31, 2008 | Intel DG965RY Motherboard
Tape loop
You may need to purchase a cheap external mixer with both mic and line inputs, and use that to mix the mic with the DVD audio. In most receivers, you can only select one input at a time. The output of the mixer can then be plugged into any spare receiver input, such as AUX, CD, DVD, etc. When not using Karaoke, you can simply turn the mic input down to prevent it from interfering with the DVD signal, but will still need to have the mixer on to hear DVD's.
Jun 26, 2008 | Onkyo TX-DS797 Receiver
Acer TravelMate 5530-5207 Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
