Question about Dometic RM2652 Refrigerator
Have dometic frig. it is gas electric in a travel trailer.the check light is on and keeps coming on. i turn the unit off then back on after a minute or so.the light will stay off for maybe 5 minutes the comes back on,plus it's not really cooling either. can u possible tell me the problem thank you.
    President:
  • 1,469 Answers
If a refrigerator doesn't cool at all, the problem is often with the basic electrical controls—almost never with a need for a boost of refrigerant.
Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the refrigerator should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the refrigerator are both set to cool.
compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the refrigerator will offer very little cooling or none at all. Call an appliance repairperson.
Hope it helps.
Take care.
Posted on May 16, 2010
  • billy_smoot2 May 16, 2010
    I JUST CHECKED AND MY FREEZER IS STARTING TO DEFROST AND THINGS ARE STARTING TO THAW OUT. I WAS WONDERING IF LOW FREON COOLANT COULD BE A PROBLEM WITH THIS MODEL RM2652 REFRIGERATOR IN MY TRAVEL TRAILER. LIE I SAID THE CHECK LIGHT COMES ON AND STAYS ON. BUT WHEN I TTURN THE POWER SWITCH OF THEN BACK ON IT WILL GO OUT THEN COME BACK ON. SHOULD I HAVE A PROPANE BOTTLE HOOKED UP OR DOES IT MATTER.
Have 1986 toyota sunrader camper. Stove lights up
The small jets at the end of the tube are probably plugged, Remove the jets and make sure you can see through them. if not then you can use a small wire to push any foreign object out of the hole.
Mar 26, 2017 | RVs
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Need instructions on how to light a rv Dometic refrigerator-
Go to this link and download 2600 PDF, last few pages are operation.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Jun 08, 2010 | Dometic RM2620 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
My check light keeps coming on my dometic ref in my 5th wheel
I have had this problem also. My experience has been that the propane line to the frig has air in it, especially after not being used for a while. Here's what I do:
1) Make sure the propane tank valve is open.
2) Light one of the burners on the stove. This may take a while but keep the gas on and a lighter at the burner. This is safe becuase as the air purges from the line it just blows the flame (from the ligher) around. Then when the air is purged the gas lights. Let the burner run for a couple of minutes. This sounds a bit odd, but what you are doing is bringing the "gas" close to the frig. The frig does not have to purge all that air as you have already done most of the purging by getting the burner to light. The facory setting for the frig is to stop trying to light after 45 seconds, and the "Check" light comes on.
3) Now try the frig. It may a couple times, but it should light and work fine.
I have found that this technique also helps with lighting the hot water.
Apr 05, 2009 | Refrigerators
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
New Travel trailer......no fridge!
Unit should still be covered on warranty call dometic directly. The tilting could affect some. If you push the auto button in it should run on electric first if no electric present it then goes to gas. Exception to the rule is if the heating element is not working it does not recognize this so it will stay on electric. Unplug the 110v in the compartment on the outside it should change to gas with in a few seconds. If it does heating element is bad.
Aug 18, 2007 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2652 Refrigerator Logo
112 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
