Question about Skeetervac SV-3100 Mosquito Exterminator
Skeeter vac won't stay lit - Skeetervac SV-3100 Mosquito Exterminator
My flame will not stay lit
The Gas orifice is clogged and needs to be cleaned. Dismantle the orifice from the gas feeder tube and soak it in a solvent such as gasoline for a few hours. Reassemble.
Nov 20, 2014 | Procom Heating & Cooling
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
My skeeter vac will not stay lit but gets lots of gas
If it lights, use a c-clamp or something to keep the fuel button pressed in until it will stay lit without the button pressed. This took me 3 hours before it would finally keep running normally. If that doesn't work, the jet and engine chamber might need cleaning. This takes some additional work and you may need to make a new fiberglass gasket since the original one falls apart after a few seasons.
May 13, 2012 | Skeetervac SV-3100 Mosquito Exterminator
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
Clothes dryer burner does not stay lit. At startup stays on for 30 seconds goes off for 25 seconds then subsequently stays on for 18 seconds.
your lint duct is in need of cleaning. first unplug next turn off gas , remove duct clamp,duct must not have more than a inkpin in thickness inside duct.tools needed,paper mask, screwdriver, vac foil tape. remove ductclamp pick pull brush and vac all of the lint, in duct and rear panel of dryer. duct must be as lineal as possible with no screws or crimps nor tears. karl
Oct 31, 2009 | Kenmore Dryers
Pilot light will not stay lit
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
Gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
Feb 20, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Skeetervac SV-3100 Mosquito Exterminator Logo
254 people viewed this question
Top Skeetervac Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Skeetervac Pool and Spa Expert? Answer questions, earn points and help others
