Question about Native Instruments TRAKTOR 3 Full Version for PC, Mac (TRAKTOR 3.0)
Numark Total Control with Traktor + monitor headphones
I am running a Numark Total Control with Traktor Pro 1.24 on Windows 7 x64. It works fine until I plug in my USB sound card (a cheap single output) I use to monitor the next track, when a system message pops up claiming the Numark TC has malfunctioned. The sound card works fine without the controller, and the controller works fine without the sound card. I am using Asio4all to control my internal and external sound devices
3 Suggested Answers
groovegsus
  • 18 Answers
SOURCE: HI, ive installed all the
You need to enable the controleler in your settings from tracktor.
In traktor open Settings - Controller manager
In device llok for the x1 controller (if it is not there add it) and also select x1 in the in and out ports.
You can also look here to see it : http://youtu.be/-g7mGPlvdMU
Posted on Aug 14, 2012
mikadot
  • 2113 Answers
SOURCE: My Traktor Scratch Duo software stops running
Make sure your hard-drive is not so full so that some of the drive can be used as cache. Make sure you have enough RAM memory on your motherboard. Use spynomore or Unhackme to make sure you are virus free. If this is a slower older computer you may still have trouble. It's best to always give specs for this type of question... cpu speed, what operating system 64 bit vs 32 bit etc.
Posted on Oct 15, 2013
Memory dump blue screen
Sounds like you are having an audio driver problem try using a different driver for your sound card
Jul 01, 2017 | Computers & Internet
I have a g4 desktop and I recently purchased the total control from numark. I came home plugged it in using the USB wire and nothing happened. Is there a step I'm missing? Help
I was just looking at a Total Control...
The unit will not do anything until it sees the host application running on your machine which is Trakor LE or Pro.
Install and launch Trakor then see if it works for you.
You may need to plug the unit into another USB port depending on what else you have plugged in.
Newmark Total Control site: http://www.numark.com/totalcontrol
Minimum System Requirements (MAC):
  • Mac OSX 10.4 or higher
  • G4 1.5 GHz or Intel Core Duo 1.6GHz
  • 512MB RAM
Jan 21, 2011 | Apple Computers & Internet
I have a Numark Stealth, DJ IO and Traktor Pro, I want to configure the Traktor Pro so that one can listen to main track on main speakers whilst I cue new track in headphones separately... how do I do...
I want to do the exact same thing. Just got my dj/io in yesterday and I'm not sure how to connect my stealth and laptop to it. U ever figure it out?
Jul 05, 2010 | Numark DJ/iO Sound Card
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
Dj io with Traktor PRO
gvjccçznvcncbdfjcvnmcmxnfbfjgkksdfsd
Jun 30, 2009 | Numark DJ/iO Sound Card
Problems with installing my Numark Total Control
best used with virtual dj..... go into configuration-sound settings... the controller will not activate until the music software is running.. on the sound set up its straight forward.....
Feb 23, 2009 | Computers & Internet
Native Instruments TRAKTOR 3 Full Version for PC, Mac (TRAKTOR 3.0) Logo
183 people viewed this question
Top Native Instruments Computers & Internet Experts
ray gallant
 Chuck N
Chuck N
JonSnell Electronic
JonSnell Electronic
Are you a Native Instruments Computer and Internet Expert? Answer questions, earn points and help others
