Question about Mtd Products Yard Machines 158CC Tiller
My pull cord won't go back in.
Can I do it myself or does it have to go to a repair shop?
  • Mtd Master
  • 8,404 Answers
Try removing the 4 bolts that hold the recoil ... you may be able to fix it or you may have to replace it ... hard to tell from where I sit without looking at it.
Thanks for visiting FixYa.com
Posted on May 16, 2010
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
Pull Cord has stripped and won't recoil. Can this be repaired?
Stripped? Maybe the recoil Spring just broke. Easy repair, sometimes you can just re-bend the 'Stop' on the old Spring
Nov 09, 2014 | Garden
When the cord is pulled out, it won't stay pulled out. It snaps right back in.
Use a small item that will fit snugly between the cord and the rim of the hole. This should keep the cord at the position you want until you can take it to the shop for repair. It's best if the item is rubber, foam, or a similar soft item that won't damage the cord.
Mar 01, 2011 | Hoover Vacuums
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
The electricy plug and cord
If The Unit Is Under Warranty There Is A Good Chance You Will Void The Warranty. But If The Unit Isn't Under Warranty I'd Go Ahead And Pull The Real Of The Tv And Repair The Power Cord Just Make Sure Everything Is As It Should Be Before You Put The Tv Back Together And Make Sure There Are No Exposed Wires Anywhere.
Sincerely,
Michael Scott
Feb 09, 2009 | Toshiba 53H71 53 in. Rear Projection...
My crockpot's cable was damaged from heat.
amy i would try to tell you how to fix this but i would cost you some money to buy all the things to fix it you might try to go to a tv repair shop and see if they could put another cord on it for you they might charge you 5-10 dollars for this k
Nov 03, 2007 | Rival 37601 6-Quart
Mtd Products  Yard Machines  158CC Tiller Logo
217 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
