Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
We got a free Sony TV from a neighbor moving out of state. No owners manual or remote, but its worked fine until today. This morning the 'sleep' and 'timer' lights are both blinking, alternately at one second intervals and the TV will not turn on. Is this 'reset-able'? How? How do we avoid the problem in the future.
  • 10,594 Answers
Unplug tv from wall socket for minute to get its timer function reset, then replug back in and turn it On.
If problem still not solve, let me know.
Thanks.
Posted on May 16, 2010
How do i fix my sony tv sleep timer it a trinitron
There is a SLEEP button in the remote of Sony trinitrone TV. Press repeatedly until the Tv displays the time in minutes (15,30,45,60 or 90) that you want the TV to remain ON before shutting off automatically. Cancel by pressing until the SLEEP OFF appears.
Hope this will help you.
Thanks for using Fixya.
Oct 24, 2010 | Televison & Video
Black screen and no sound after a few minutes.
First, here is a copy of your manual in case it is missing.
http://www.warrantyweek.com/library/ww20061219/panasonic-th42px60u-manual.pdf
Next, check the settings of the sleep timer.
Select on the remote:
Menu.
Timer.
Sleep.
See if there is a time setting in there. You may also find a shortcut from the remote labeled "Sleep".
If this fails to resolve the issue, you can always reset to factory defaults. To do this, select from the remote:
Menu.
Setup.
Reset.
Hope this helps. Be sure to let us know how this helped.
Jun 30, 2010 | Panasonic TH-42PX60U Television
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand by time is flashing tv will not start
no the tv has no battery for memory.the memory is supplied by the 5 volt standby.the tv must be plugged in to maintain the 5 volts to keep its memory.
Jul 18, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Can't get picture
Check to make sure you are on the correct input. Example: Video 1, Component 1. How are hooked up? Are u using coaxial. If so you should be on TV.
Apr 07, 2009 | Televison & Video
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
SONY KP 51WS500 - Volume & Menu won't stay on
This would be weird for a sony but it sounds like the volume down button on the front of the set is stuck...very very uncommon for a sony. Try taking the bottom front cover off the set and unpluging the button assyembly then see if the remote works the set with it unpluged.
Tim nolan
Sep 17, 2008 | Sony KP-51WS500 51" Rear Projection...
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
