Question about Frigidaire ATF6000ES Front Load Washer
Hello my frigidaire door is locking so we think that we may need to buy the board how much do you think that wiil cost
  • 5,081 Answers
It will cost around $200.
You can buy it here in the link below:
http://www.repairclinic.com
Posted on May 16, 2010
What corrective action for e47 code?
Hello. I need the model number to help you accurately but I'll assume you have a Frigidaire washer. If so, then the E47 code is telling you that the main board thinks the door is open on spin. Go to this web address and it will tell you how to check the electric door lock mech. http://forum.partsdr.com/showthread.php?1-Frigidaire-Washer-E47-Error-Code. If you *don't* have a Frigidaire unit, please post a comment with the brand/model number so I can give you exact information. Thanks!
Sep 11, 2015 | Washing Machines
Error code 47
The main control board thinks there is a circuit open in the spin cycle. A professional is needed to complete the following:
Sep 18, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washer that gave me a error 47 code. what can that be.
The circuit thinks the unit is in spin cycle - Remove the door lock assembly and measure the resistance of the PTC. Shorted or open, defective door lock assembly. Reads around 1500 ohms, defective Main Control Board.
Aug 19, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity gas dryer problem
I would bet you need new door lock switch
Jul 13, 2017 | Frigidaire Dryers
I have an Frigidaire Affinity Washer Model ATF6700FS1 got error code E41. Thinks the door is open. I tried unplugging the connectors to the door switch but nothing worked. What to do now?
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire affinity ATF8000FS2 went thru the wash cycle but won't spin. Error Code is 41. How do I fix it. The washer is only 1.5 years old and is used maybe once or twice a week. I hope this is...
Kevin
Aug 01, 2011 | Washing Machines
PAU error code comes on when iI test it it shows e41 door lock
Hello, welcome to FixYa
Based on the info you provided, specifically the E41 error, It sounds like the unit is detecting an unlocked door, loose wire, or the control itself is bad. (E41= Shorted or open. Defective door lock assembly.Around 1500Ohms. Defective control board.)
The PAU simply indicates the control thinks it has been paused...that may be just a side affect of the door lock assembly.
Here's how to check...
**Unplug the unit from the wall first...safety first**
Remove the door lock assembly and measure the resistance of the PTC. Should get a reading of around 1500ohms.
Attached here is a great tutorial for accessing the assembly for testing and replacing.
http://www.repairclinic.com/PartDetail/Door-Switch-Assembly/131763202/1531974
Let me know if you need further assistance going forward or if anything is not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Jun 16, 2011 | Frigidaire Affinity ATF7000ES Front Load...
FRIDGIDARE WASHER MODEL LTF6700FSO DOOR LOC ERROR. DOOR WILL NOT LOCK. HOW DO YOU REPLACE THE DOOR LOCK?
How old is this unit? Usually these locks cost an arm and a leg. This is especially true with units like: G.E, Frigidaire, Hotpoint...These are units that are owned and operated under General Electric. First, if you have a volt-ohm-meter, do a continuity check on the switch itself. Then if that checks out, your next culprit would be the main control board (most likely).
Dec 14, 2009 | Frigidaire Dryers
My Fridgidare washer Model #GLTF2940ES3 keeps flashing an "E70" error code. Could someone please tell me what this means?
Hello there :
this 70 code has 2 possible causes
(1) a control board which might be in need of replacement. (costly to replace )
(2) the door lock assembly which could be bad. (fairly cheep and simple to replace ).
I would first shoot for the lesser (least costly of the two) and go with the door lock and this will be the problem if not this controle board can be costly to replace ok ?
I hope that this has helped you out
best regards michael
Oct 22, 2009 | Frigidaire Washing Machines
Wash machine won't spin.
If you want you can jump the switch out by taking the wires off the switch and put electrical tape around them together really tight and see if that works if so its your switch thats bad
Aug 24, 2009 | Frigidaire GLTF2940F Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
11 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
