Question about LG 22" FLATRON LCD Monitor
Lg Flatron L226wTQ, power button failing
Lg Flatron L226wTQ, beofre I toss this out, was wondering if there is a quick fix. I get no power when I push the button.
  • 1,684 Answers
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on May 16, 2010
  • dazdaz Jan 06, 2011
    It looks very helpful. The pics and instructions are very clear - I'll try to fix my LG L226-WTQ this weekend and post the results.
    I found that RadioShack has the 1000µF 35V 20% Axial-Lead Electrolytic Capacitor for $1.69 http://www.radioshack.com/product/index....
How do i get the back off a lg flatron l227wtg monitor
Posted on Aug 30, 2010
Monitor sleep problem
This type of problem is usually caused by a failure of the filter capacitors on the power supply board. The LG L204ws uses the AIP-0156 power supply which is the same board used in many of the LG monitors that were sold around the same time. Here is a link to a repair guide for the LG L226wtq model that used that board. The repair guide as pictures and videos showing how to open the unit and check the filter caps. There are parts lists showing what needs to be replaced too.
I hope this helps,
BuddyMc
Dec 01, 2012 | Computers & Internet
Hello my flatron l206wtq-bf doesnt work the light of power flash blue and the monitor doesnt open do you have a solution for me thanks
Your unit has a power supply that has failed. When the power board starts failing you may get a wavy display, it may be slow to show a picture or you may just get the flashing power button light that you have. The problems are caused by parts called capacitors that have bulged and failed. Here is a link to a repair guide for the LG L226 that uses the same power supply board as your unit.
The dis-assembly information is almost the same to.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 01, 2011 | LG FLATRON L206WTQ-BF Monitor
My LG Flatron L1715S works sporadically - it is blank when activated, but activates either by pushing the on-off button many times OR by rebooting several times. Is there a quick fix to this that does not...
No, sorry, it's not a simple fix. The usual reason an LCD monitor does this is because capacitors in the power supply fail. Then the inverter circuit which provides power for the backlight lamps doesn't work properly. In many cases, replacing the capacitors is all that's needed to fix the trouble, but it means opening the case, removing the bad parts, and obtaining and installing new ones. It's not a very difficult repair as far as repairs go, but it's going to need more than a screwdriver.
Many websites and videos are available that detail the repair procedure for different models, and capacitors are readily available from many sources. If you know someone who has some experience with electronic soldering, or you're willing to try it yourself, you might be able to rejuvenate this one. If not, you're probably best off buying a new monitor. Basic models are quite inexpensive now, and if you pay someone to fix yours it might cost nearly the same.
Jun 07, 2011 | LG Flatron L1715S 17" LCD Monitor
I have an LG Flatron L226WTQ-SF and my monitor has some "shadowing". If you need more infos I can send you some pictures.
If you are using analog VGA cable, replace it with one that has ferrite rings near both ends. The best is to use DVI digital cable but this depends on the capabilities of the videocard and the monitor ofcource, but I think this monitor has DVI input.
Aug 05, 2010 | LG L226WTQ-BF Monitor
I need window 7 driver for a lg flatron monitor L226WTQ-SF Cheers
There is no need to install any driver for the monitor as the inbuilt drivers always work with all operating systems and windows 7 have thousands of drivers inbuilt.
Mar 05, 2010 | Computers & Internet
Screen flashes on for around 1-2 seconds before turning off
Your TV has a defective component on the power supply section. Need service by electronics technician.
Jul 27, 2009 | Computers & Internet
My screen on my Lg Flatron L226wTQ=bf went white. I tried rebooting it a few times and have also tried uplugging it. I have plugged in my old monitor for now which is working very well. Can you help me?...
Its either going to be the lcd or the inverter is bad. Keep in mind that the cost to repair the monitor is going to be more then its worth. Also make sure that your pins on the vga cable are nice and straight, bent pins can also cause this type of problem as well.
Jun 12, 2009 | LG 22" FLATRON LCD Monitor
LCD Flatron 21inch going into power save mode problem
this is not a problem with the monitor, it looks as your computer is not sending any video signals to the monitor thus it goes into saving mode. Take a look at the computer, check the video card. Pull it out then turn it on, turn it off again and place the video card where it should go then turn the PC on again. This should clue the OS to re-configure the video driver. Did you try another monitor ?
Jun 03, 2009 | LG 22" FLATRON LCD Monitor
LG FLatron 22 Inch : model number (L226WTO - SF)
It's problem in properties of monitor.I have LG l226WTQ and i'm having home bad things like http://img.youtube.com/vi/MzQtRBtrvc8/default.jpg
I don't know how to solve this :'(
Dec 02, 2007 | LG Flatron L2320A 23" LCD Monitor
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
LG 22" FLATRON LCD Monitor Logo
2,723 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
