Question about Sharp Microwave Oven Microwave Oven
I have a Sharp R9600 microwave oven that still works but the "start" touchpad has worn down and it is difficult to start the oven. I have been unable to find replacement pads so I wanted to know what size the R9600 oven is? My preference is to replace the pads but if I can't find them, I want to make sure the new oven is at least the same size as the R9600.
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel R-201EW 600 Watt
The keypad is available separately (you have to peel off the old one and stick the new one on) for about $36 plus shiping. It is also available preassembled with a new control panel frame and display for about $78 plus shipping. They are available from Tritronics at http:www.wehaveparts.com BUT - I would first suspect and check for a failing door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files via a Google search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide, but it's usually a door switch. If you still have a problem, please write back with more detail. Be safe!
Posted on Oct 14, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Posted on Jun 08, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: User's Manual of Sharp Microwave Oven Model R-9H56
Found this posted under Whirlpool instead of Sharp, but I'll be happy to answer it here.
While that one may not be available, we have one that may be close enough to work:
http://www.microwavedisplay.com/r9h66_r9h76_r9h84b_r9h94b_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Dec 31, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
Sharp microwave R-410LK fan and light do not turn off.
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Oct 23, 2013 | Sharp R-410 Microwave Oven
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
Need a touchpad replacement for SHARP CAROSUL CONVECTION MICROWAVE OVEN MODEL R - 9 H 20 ( M ) / ( W ) please. Where can I get one?
You can go online to Sharp and link to the techical department, or check tv repair store, and appliance repairman, may have what you are looking for or may be able to get the part.
Mar 04, 2012 | Microwave Ovens
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
R-8350, No power to touchpad, but interior light works
The touchpad has its own fuse which has probably blown due to a surge perhaps related to the turning on of the fridge. Removing the cover from a microwave is potentially lethal due to the large capacitor to drive the magnetron. However, this is usually well away from the front panel. If you do venture in you should first unplug the unit and when the outer cover is removed, discharge the large capacitor with well insulated pliers -= otherwise keep well away from it. The fuse you are interested in is on the pc board behind the touchpad. Replace it with exactly the same fuse (usually a slow blow fuse).
Sep 22, 2009 | Microwave Ovens
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
My microwave touchpad doesn't work
OK, i have located the actual part you will need. i found the part number. click the link below to be directed to the Auto-Touch Control panel you are seeking. you can order form this site as well if you choose.
Auto-Touch Control Panel
May 16, 2009 | Sharp Microwave Ovens
Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes the problem can be undone also.
Feb 09, 2009 | Sharp R-540DK Microwave Oven
Error code on touchpad....
EE4 means that the unit is not set to the proper level for the line voltage at the place where it's installed, or that may have a faulty outlet or power line.
Assuming yours is a Sharp R23-series, we have uploaded the full service here.
But I've attached an excerpt to show you how to check / set your proper voltage level.
May 19, 2008 | Sharp R-23GT Microwave Oven
Sharp Microwave Oven Microwave Oven Logo
140 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
