Question about Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duett washer keeps filling with water ... causing it to overflow.
  • 5,911 Answers
The problem you describe is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose and repair each problem yourself:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included steps on how to replace any defective parts and part resources if you need to order anything. If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 16, 2010
Whirlpool LSR8433KQ keeps filling with water and overflows. What can I do?
Pressure switch W10339229 or inlet valve may be stuck. If the water shuts off when you push in the timer knob to stop the machine, then water valve is ok. Try a different water level setting.
Mar 30, 2014 | Whirlpool Washing Machines
Washer wouldn't stop filling and leaks
Hello, here is a great link to check out everything you can think of on your washer repair and trouble shooting. Make sure you really check out the different areas to click on on this site..
Here is the link. I hope this helps you, mike
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Oct 20, 2011 | Whirlpool LCR5232H Top Load Washer
Washer keep filling with water and will not kick over to next cycle mode for wash or spinning cycle on cold water?
Hello, Assuming the washer doesn't keep filling to the point it is overflowing the tub, it sounds like you have a bad lid switch. If it is overflowing then you may need a pressure switch or more likely the pressure switch tube (surgical tube) is just clogged where it connects to the outer tub. You can go to - http://www.searspartsdirect.com/partsdirect/index.action - Type in your model number then select model search. You can get part breakdown and buy parts for most brands. Good Luck.
Mar 12, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Washer continues to fill and overflows
start to fill the washer,then turn it off,if water still keeps filling you have a bad inlet water valve,if it stops then check the water level water hose from the water level switch to the side of the outer tub-mike
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Whirlpool washer overflowing
Water pump on the washer has gone out. Have it fixed by a technicain. Or if you are a do it yourselfer like me.
Go to http://www.repairclinic.com/
Feb 10, 2008 | Washing Machines
Overfilling Whirlpool cabrio washer
Great! It may be the water level control switch. So, where is it and how do you check it or fix it or replace it?
Jan 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet Sport HT WFW8400TE Washer Logo
243 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
