Question about RTO PasLode 900420 Impulse Framing Nailer
Framing nailer has freshbattery, good fuel cart, fan runs when you put pressure to the charging head nails,,,,, but will not fire.from what I've read up on this, it sounds like the combustion chamber has a leak. how tough is this to fix?
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
Fires when air is plug in,driver stays out.
Most likely problem is the firing valve (tva6), easy to replace and not expensive. Good time to remove the head and lube headvalve with white grease. For now be sure to remove the nails after use and install nails after air connected. Good luck
Jun 20, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
Paslode cordless framing nailer doesn't fire
check date on bottom of fuel canister, fuel goes bad
Sep 17, 2012 | SK Paslode Sk312 Framing Nailer O`ring...
Quit firing nails motor comes on but nothing happens when pulling trigger
I am assuming that you have changed the gas cylinder. Make sure you have the exact correct cylinder, because there are some that look like they fit, but don't quite seal. This unit requires battery charged for ignition and induction fan. And it requires fuel to drive the nail,.
Oct 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
What preasure does a rockworth framing nailer need to operate
You did not provide brand, but this broad spectrum will give you some indication. Framers operate, depending on the brand, on 45psi (2.5bar) to 120psi (8.3bar).
Setting depend on several variables, that is thickness of the timber, hardness of the timber, lenght of the nail, to certain extend hardness and diameter of the nail..
You know that pressure is correct to material when nail head is flushed with surface of the timber or very slightly below.
If nail stick above the surface, you need increase pressure (in stages! do not jump from one extremity to another!), till you achieve flash suurface.
if nail takes "dive" and is more than thickness of the head below the surface, you need to decrease the pressure till you achieve this "golden" level of flush or just below the surface.
Sometime there is necessity to drive nails into totally unsuitable surface of timber (for example bamboo, yes, I know it sound ridiculous, but not everyone live in north america...), it is then good idea to spray nails with teflon or silicone oils, This treatment allow penetration even in bamboo, mahagony and other timbers harder than 12 in Jenkins scale without riping them apart.
Albeit if I see you firing nailer in my workshop into mahagony I will fire you... :-)
Hope this short intro into the noble art of framing and pneumatic nailer world will help you. Do not forget wearing protective glassess or face shield while using nailer! You have only two eyes and there is no spares...
Aug 15, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Wiil a 22 degree Paorter Cable FR350A Round Head
No... it will fire 21-degree nails and perhaps 23-degree nails (but sont think they exist) and it is a full-head framing nailer so it is designed for firing round head nails. Using clipped nails will likely jam the nailer as these nails are stripped closer together with overlapping heads in the nail strip and the FR350A has a full round driver so you will run into issues with clipped nails. If you are having problems finding full round head nails, you can find them on Amazon to fit this nailer. Otherwise any good tool or trade tool store that sells nailers will likely have a suitable nail supply available for the FR350A.
Feb 09, 2010 | Porter Cable Air Tools & Compressors
Nail not firing, battery charged, fuel cell good,
When you took it apart to clean it, you may have piched off the large brown o-ring on the head valve. To check this, take the orange head valve cover off and push the gun downard onto a piece of wood as if firing it. Watch the o-ring to see if it clears all the metal fingers around the fan.
Dec 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
May 31, 2009 | Stanley Bostitch Coil Framing Nailer
Paslode im250 f-16 only able to drive 2 nails .
Bad Fuel cell!!! New cyliders now have expire date on bottom of cannister. If old will not fire properly. Put new fuel cell in should be fine.
Feb 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
RTO PasLode 900420 Impulse Framing Nailer  Logo
217 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
