Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
Brightness of digital clock/timer 318012900
Numbers in digital clock/timer 318012900 on Frigidaire FCS388CE dual-fuel range have become very dim and difficult to read. Is there an adjustment or procedure to increase brightness? Cannot find any reference to this in the manuals. Have power-cycled the range but no change.
  • 76 Answers
SOURCE: Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Posted on Jan 07, 2007
Junoon007
  • 1011 Answers
SOURCE: Frigidaire Range model FEFL79DSJ has electronic clock/timer
Dear Sir/madam,
Connect an ohmmeter across the terminals and advance the timer to see if the switches
are opening and closing OK. If not or the motor doesn't run - replace the
timer. Since the burner is
inside the oven, you cannot immediately see if it has ignited. Different manufacturers have designed
different methods of keeping the
gas safety valve closed, until ignition is guaranteed. The oven
thermostat valve is set by hand to control the oven temperature. In some types of systems, the
thermostat is not a valve at all, but an
electrical switch that opens and closes by oven temperature.
The
gas safety valve prevents gas from flowing to the burner until ignition is assured. If it has an
electrical thermostat, it cycles the safety valve. On and off as long as there is ignition.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 29, 2008
SOURCE: Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Posted on Aug 02, 2008
SOURCE: frigidaire duel fuel range model
I have the same problem with an identical oven. In fact my serial number indicated my oven rolled of the production line six ovens before yours.
Please let me know how you fixed the problem.
Thank you.
Kaid
Posted on Feb 13, 2011
Daniel S
  • 4323 Answers
SOURCE: My Frigidaire FEFL77ABF range oven gets too hot.
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 09, 2011
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Setting the clock
To set the time, turn and hold the Timer knob to the clock
symbol = and at the same time turn the Adjusting knob left
or right until the clock shows the time of day. Remember this
is a 24-hour clock. Let go of the Timer knob and it will spring
back to the vertical, oven manual setting.
Dec 05, 2012 | Rangemaster Toledo 90 (Dual Fuel) Dual...
I have just moved into a house with Leisure rangemaster 110 dual fuel, how do i change the time on the clock have pressed all knobs in various sequences, found the automatic, the timer but cannot move it...
http://www.rangemaster.co.uk/Siteimages/Site_311/Pdf/ProfessionalPlus110DFOct08.pdf
User manual.
When the clock is first connected, the display flashes ( 0.00) and (?) alternately. To set the time, turn and hold the Timer knob to the clock symbol (?) and at the same time turn the Adjusting knob left or right until the clock shows the time of day. Remember this is a 24-hour clock. Let go of the Timer knob and it will spring back to the vertical, oven manual setting.
It is on page 6 of manual
Mar 28, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Ilve electric oven modle P 90 WMP. the digital
on the back of the clok is 4 wires the brown and the blue suply power for the clock and timers functions the 2 reds the timer makes these live if only one is live when set to manual then its best to replace the clock or if you can change the relay that the wires ar conected too
Jan 24, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
The electric control panel
dimming of the control panel is only rectified by replcing the display board/clock assy.
Nov 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador 30" Dual-Fuel Range 0FF error
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Dim Digital Display
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
77 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
