Question about GE 31GT660 TV
Our TV shuts off out of no where. No surge. No reason. If we turn the electrical source off for a few minutes, we can plug it back in, and hit the ON/OFF button once or twice, and it will come back on. But it takes a few minutes to reset. This is maddening, and we just don't know what to do.
  • 712 Answers
May be it is the t.v transformer. Check if it is all right. If not get it replaced. You can easily check if it is the transformer if the time between switching on and automatic turning off is getting reduced every time. Transformer is a small and cheap equipment readily available in the market. It may be damaged due to lightnings or voltage fluctuations. It is very simple to replace it. When you buy a new one go for the best one available in the market. Else the new one too can go out soon.
Posted on May 16, 2010
  • dawnmarie644 May 16, 2010
    Can we do that ourselves? Must we bring it in for repairs?
  • Sebin Punnacheril
    Sebin Punnacheril May 17, 2010
    You can do it yourself if your are good in electronics and love repairing. Just open the backside and remove it carefully. Its a lot simple. But if you think you can't do it all by yourself then try calling a repairman.
I have a Vizio SV48OM. It is hooked up to Dish. this morning I couldn't change channels or anything with my dish remote but could turn the tv on and off. Called dish and was trying to see what the...
About the only thing you could try would be to reset both the dish receiver and the tv. Disconnect both from electrical power source, (unplug) after a minute or so, plug them back in and try again. if neither works then you may have had some type of power surge.
Be certain your tv is in the right source, however the tv has been connected to your receiver.
Oct 29, 2013 | Vizio SV470M LCD TV
I have 20MC4306. Recently when you turn it off it turns itself back on. Also when you turn it on shuts off after 2 seconds. Tried putting in a video vhs then press play and wait few seconds and hit...
Sometimes when the TV recives a brodcast signal for a new update to the mainframes firmware, it will have to turn itself on to install/recive the update and aslong as it is connected to a power source it can do this. hope this helped answer your question. Have a good day :)
Jan 03, 2011 | Philips Magnavox 20MC4306 20" TV/VCR/DVD
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
LG 50" plasma will turn on then shut off shortly there after.
Unplug the power from the power outlet and let it sit for a few minutes. Then plug it back and it should work normally.
Apr 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
HP Pavilion MD5020N 50 in. HDTV DLP TV keeps shutting down
ok this is what you do folks.... un-plug the tv from the power supply. once that is done hold the power button down on the side of the television for 30 seconds. this will release all electricity out of the tv.... then before you plug it back in hold the channel down vol up button along with the power button at the side on the tv this should reset the tv and it will start up automatically on video one. Select your source and scan for your cable channels again. If the problem is not solved then contact someone to come and clean the filter for the tv because it may be clogged along with this it can be the color wheel and may shut itself off like 3 times until it feels it is right.
Apr 08, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Pioneer Model SD-P4571 Problems?
It could be because of where you live.
Hi humidity, High temperatures where you live, etc.
Try placing a cooling source next to it, like a small portable air conditioner and even a fan.
Also, please try installing a GFCI outlet AND plug a surge protection outlet strip for all components and tv.
Any spike in your electric circuit, for example, a refrigerator starting, a furnace running etc. can cause the tv to turn off.
Regards,
Yalmer
Mar 13, 2008 | Televison & Video
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
GE 31GT660 TV Logo
24 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
