Question about Whirlpool Duet GHW9150P Front Load Washer
"control locked" light is on washer
The "control locked" light was on my washer when I started to do a laundry and wont allow me to do anything...
  • 5,911 Answers
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on May 16, 2010
2 Suggested Answers
SOURCE: Kenmore Elite HE4t Washer - "Control Locked"
I followed dpgord suggestion and held down the "Drain & Spin button" for a few seconds and it fixed it.
Thanks, you probably saved me the cost of dinner in a nice restaurant. Who knows, with today's prices you may have saved me air fare to Hawaii.
Posted on May 22, 2008
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Adjacent to the "Control Locked" light is the DRAIN/SPIN button. Push it in and hold for 3 seconds. This should unlock the control panel. If it doesn't, let me know.
This is a designed feature of the washer to lock the controls to prevent small children from accidentally turning the washer on or manipulating the controls in any way. The control can be locked by holding the DRAIN/SPIN button in for seconds, and released the same way. If someone leans against the button this can also occur. Hopefully this will be an easy fix for you. I hope this helps.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
May 23, 2008 | GE WSXH208A Front Load Washer
Frigidaire (gallery series) err problem
ck to see that a control lock light is not illuminated, as far as fisher and paykel pressure swithc is part of motor controller under main console. removing screws behind console allows you access and from ther i would remove clear plastic tubing from right side of control and blow down the line (sometimes detergent will block other end not allowing proper readings)
Feb 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
I pressed and held drain/spin and it unlocked the controls... try it and let me know.
Nov 25, 2006 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
