Question about Fisher and Paykel GWL11 Top Load Washer
Doesn,t pump out water
Doesn't pump out water and there is a high pitched sound when it trys
  • Fisher and P... Master
  • 3,051 Answers
Hello there:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on May 16, 2010
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Hot watertank puts out high pitch sound
It is probably the water passing through some restriction such as a valve or maybe a T or 90. If this is correct changing the water flow will change the pitch and it will be absent when there is no water flow.
If that doesn't change or eliminate the high pitch sound I do not have a clue.
Jan 09, 2014 | American Standard Water Heaters
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
High-pitched whine upon cranking, suddenly sluggish, smells hot
It sounds like the water pump shaft bearing has frozen up. A hint here, always replace the idler pulley and water pump when you do the belt, they make kits for this and they have all the parts that wear out along with the belt. As long as the engine doesn't get to hot you should be ok.
Jul 02, 2012 | 2000 Honda CR-V
High pitched noise coming from front of engine only at high speeds. When at low speed, it mainly sound like a higher pitched tire noise. Any suggestions would be helpful
check the altenator berrings, also check condition of air pump it may be going out,don;t forget the water pump berrings
Sep 25, 2011 | 1993 Chrysler Lebaron
Have a pentair 1 HP whisperflow pool pump. It makes a loud high pitch sound when turned on. Sometimes when first turned on it won't but quickly will begin making the loud high pitch sound. Almost...
Are you sure that you have it wired the right way. it has a setting for 220 or 110 the pump will run if it is not wired correctly however it will be varey ******* the brushes inside the motor resulting in a loss of efficiency
May 22, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Have 93 Chevy G 30 Have a High pitch whine that changes with rpm
This could be anything from the pump in the transmission to the alternator bearings/bushings to the power steering pump. Could be an idler pulley bearing, but I doubt it.
Hint: If the noise is very high-pitched, check the alternator. If it is a lower, medium-high-pitch sound that changes some when you turn the wheels, check the power steering pump. If it is almost like a moan or a "Whooo" sound, that's the transmission pump.
Feb 23, 2010 | 1994 Chevrolet Sportvan G30
JD LA105 with 19.5 BS intex engine. Under load with mower engaged engine will begin to run unevenly and as the gov trys to compensate I hear this high pitch chirping sound. Any idea where I should be...
It sounds like a head gasket is blown,with the engine cold start it and spray water on each exhaust pipe,if one cylinder has a problem it will run cooler,the water will tell you which one is running cooler.Also you might want to clean the carburetor and check the fuel cap vent.
Aug 08, 2009 | Garden
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
Aug 04, 2009 | 1996 BMW 318
Fisher and Paykel GWL11 Top Load Washer Logo
369 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
