Question about Whirlpool GU2400XTP Built-in Dishwasher
My Whirpool Quiet Partner III has no power. I
My Whirpool Quiet Partner III has no power. I checked all breakers, all are properly on. Is there a reset button somewhere on the dishwasher?
  • Whirlpool Master
  • 3,051 Answers
Hello there: It doesn't work at all If your dishwasher doesn't work at all, check these: Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on May 16, 2010
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
What is the reset code for a whirpool plus quiet partner III
heated dry and high temp wash and toggle back and forth these 2 keys within 8 seconds till all the lights light up.
Aug 30, 2010 | Dishwashers
How do i check for gloggged jets
clean filters,then run a wash tablet through machine without a load.adrian,,,,
Jul 15, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
See below
have you tryed leaving the power cord out of the socket for an hour or so
sometimes they don't lose the memory until they have been left disconnected for a while
Jun 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,427 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
