Question about HTC 2020i Smartphone
Helo im having problems in syncronizing my pda to a computer... my computer doesnt recognize my pda..what should i do??? help please.. tnx
    Problem Solver:
  • 19 Answers
Have you installed the newest version of 'active sync' ?
if not, google for it and install it.
Posted on Mar 31, 2008
SOURCE:
The syncronizing software for OZ-290HII will not work with my computer,though it installs,it keeps saying (file export failed) and this unit has a USB cable. I followed all the instructions but that...
Hello Sr,
Kindly read this, it may help you.
When the software that lets your computer communicate with your PDA acts up, always check the cables and connections first. Is the USB (Universal Serial Bus) or serial cable connected securely to the PDA (or cradle) and the PC? Is the PDA seated properly in its cradle if it uses one? If everything is in place, visit the palmOne (www.palmone.com/us/support/downloads) or Windows Mobile (www.microsoft.com/windowsmobile) Web site and download the latest version of the HotSync or ActiveSync software that is compatible with your PDA and your computer's OS. Keeping synchronization software up-to-date is important because newer versions fix compatibility problems and usually add new features.
If you have a Palm OS PDA that uses a USB connection, sometimes incompatibilities exist between Windows and the software that you can resolve only by running a special USB utility found at the PalmOne download site mentioned previously. Select your hardware from the drop-down list and click the USB Registry Utility link. Download the USBRegClean.exe file, navigate to the downloaded file, and double-click the icon to install it. Reboot your computer and reinstall the Palm Desktop and HotSync Manager.
...contd
Mar 09, 2008 | Computers & Internet
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
I formatted my HDD and now it says Keyboard Not Found
Your problem is that you need the file for your keyboard. This sucks because you are already in the middle of a reboot situation. Do you have your old keyboard or another one to get you through?
Dec 26, 2008 | Gateway 7001433 Keyboard
Sony Walkman NWZ-S615F problem detecting and syncronizing
I had the same problem. One day my Mp3 started acting weird and said it was not recognizing the files and that i needed to re download them. Try plugging it up to your computer while its charging and hit the power off. Then reset your mp3 with the button at the bottom and it should recognize it.
Nov 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Driver for nec versa fm 340
http://www.nec-computers.com/support/main.asp
choose
notebook/pda
versa
versa mainstream(veras M)
m340/Fm340
Mar 03, 2008 | Microsoft Windows XP Professional With...
Wi-fi PDA connectivity problem
First, restart your pda by using your stylus and pressing the pin-hole sized button on the back of the PDA. There are sometimes a couple of different reasons why the pda wont recognize the network. Main Reason: Make sure you are at the home screen... Tap the wifi icon on the lower right corner of the pda. T hen make sure that the WLAN power is turned ON. Press the setting button. If you see your network in the list, tap on it. It should bring up a network configuration window. Make sure it says it connect to "The Internet". Then tap on the "Network Key" tab at the bottom of window. If you have no security settings on your belkin router, make sure Authentication is set to Open and Data Encryption is set to "Disabled". Then press "OK". That should Be it!!!! Let me know if this way doesnt work, or if something doesnt make sence!
Sep 15, 2005 | Dell Axim X50v Pocket PC
Zire 72 Won't Sync Notes
I feel your pain as I'm having even more problems than you, see my post. However, having learned quite a bit about this topic, I suggest ensuring the Hot Sync is set for the desktop to overwrite the PDA as opposed to PDA overwriting the desktop, which sounds like what's happening. That's the only suggestion I have. Hope it works out for you.
Sep 11, 2005 | Palm Zire 72 Handheld
Open Questions:
See all HTC 2020i Smartphone Questions
HTC 2020i Smartphone Logo
70 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
