Question about KitchenAid Dryers
Dryer will not start and you can hear the timer motor moving
  • 1,344 Answers
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it starts, or you can use a multimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. Another possible problem is that the door switch isn't functioning properly. You can visually check this by open the door and pressing the switch and listen for a click sound upon pressing and releasing .
Posted on Jun 05, 2012
mreid542
  • 166 Answers
SOURCE: timer motor keeps running on dryer
sometimes as a timer gets older the timer motor will get a little loud. timer motors run even when the door is open. if the timer advances to off and everything works fine you don't need to worry about it.
Posted on Nov 20, 2008
  • 1122 Answers
SOURCE: dryer will not start when start button is pushed, but timer motor
door switch or main fuse on blower box is bad-mike
Posted on Dec 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
dniro592006
  • 121 Answers
SOURCE: Timer doesn't move, otherwise dryer is fine.
Timer needs replaced
Posted on Jun 12, 2009
SOURCE: I have a kenmore 70 series electric dryer. The
There is a circuit board that is in the control panel. It is mounted into a plastic carrier that is skrewed into the panel. You could pull it straight out and check it with a multimeter to see if there is continuty, check the two blue resisters and if no continuty, replace!
Posted on Jun 29, 2009
Timer won't stop after cycle finished.
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
May 20, 2015 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Fisher and paykel dryer not working
If what you meant is that the dryer does not work but you hear the clicking noise , the fault is due to a faulty TIMER.
The stepper motor within the mechanical timer unit is SLIPPING either at the gear or the tooth and so doe not make the timer to move forward.
You can remove the timer and use some WD 40 but if there is wear-off on the gear the timer must be replaced unless you can source this from an old unit.
Nov 07, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore dryer quit running. I don't hear the timer moving and motor is not moving the tub. I've checked the circuit breakers and they are not tripped. I've even reset them. I'm about to check the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2010 | Kenmore Dryers
My Maytag DE4000 timer will not move once the dryer is started. The dryer will run until manually turned off.
there is a clock motor in the timer ether its not geting power or has a striped gear if you can hear it runing then its the gear
Oct 20, 2009 | Maytag Neptune MDE4000 Electric Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
Electric Dryer problem
the timer has a small motor to advance the timer. the motor is the likely problem. on some old maytags you can get just the motor, but you probably will have to replace the complete timer. hope this helps.
Oct 25, 2007 | Dryers
Open Questions:
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
