Question about Apple 24" iMac Desktop
PREVIOUS SYSTEM ISSUES - Apple 24" iMac Desktop
  • Apple Master
  • 13,433 Answers
Hello, please be specific, what kind of problems are you having?
Posted on May 16, 2010
  • hpridgen May 16, 2010
    I archive and installed from an install dvd and then had a new desktop. Now I am trying to get things back from a previous system I found on the hard drive. I have two mail applications in my dock and I am finding an application in the previous system that I have in my new system and I am trying to trash things because I am running out of space. Can I trash the previous application if I have one in the current system?
  • Ekse May 16, 2010
    yes you can
I have Vista lab top hp and I need to upgrade to windows ten or do I have to do seven first
you have to have a previous system to up grade
there are problems with the upgrade with many questions to this site with problems associated with the up grade from incompatibility issues
it is better to get win 10 and download rather than up grade from an existing operating system
Aug 10, 2016 | HP Computers & Internet
Tip
How to perform a Sony VAIO System Restore
NOTE: A recovery also can be performed using recovery discs.
  1. Close all open programs and turn off the computer.
  2. Disconnect all network connections.
  3. Disconnect all peripheral devices.
  4. Turn on the computer.
  5. When the VAIO screen is displayed, press the F8 key.
  6. At the Advanced Boot Options screen, ensure Repair Your Computer is selected and press the ENTER key.
  7. In the System Recovery Options window, under Select a keyboard layout: , click the Next button.
  8. Under To access recovery options , next to User name: , click the down arrow , and click to select an account with Administrator rights.
  9. Next to Password: , type the appropriate password for this account.
  10. Click the OK button.
  11. Under Choose a recovery tool , click to select the desired option: NOTES:
    • The Startup Repair option can automatically resolve certain issues that can prevent the operating system from starting.
    • System Restore can return the computer to a previous configuration of the operating system when it was working properly.
    • Windows Complete PC Restore will restore a previous backup of the computer created using the Windows Backup and Restore Center .
    • The Windows Memory Diagnostic Tool can determine if any problems being experienced are caused by issues with the computer's memory.
    • The option to open a Command Prompt can be used by advanced users and technical support personnel to perform troubleshooting on the hard drive or the operating system.
    • Clicking VAIO Recovery Center will launch VAIO Recovery Center from the Recovery Disc.
on Feb 11, 2010 | Computers & Internet
Air bag light is flashing code 18. This happened after installing a new radio. I unplugged the PAD light. Is there a way to clear this?
Is the PAD plugged back in? The SRS system is designed to run through a self diagnostics every time the key is cycled on. If there are no issues with the system there should be no reason for the light to come on. even with a previous error, the system should reset when it detects no errors it will just store a history code.
Aug 20, 2015 | Cars & Trucks
My 1996 acura tl v6 is having issues with overheating. we bleed the system,aintfreeze and coolants have no leakage,replaced the temperature control sencor aswell as the thermostat.The radiator was replaced...
have a compression test done to check head gasket and for cracked heads . Have the radiator flow tested as the previous owner probably used a second hand unit to sell the car that was partially blocked any way.
Aug 08, 2014 | Cars & Trucks
Overheats because engine coolant backs up into reservior.
That's not the cause. That is the effect of boiling. Start out by pressure testing the cooling system to locate any loss of pressure and repair it. It's possible that previous overheating has led to head gasket issues now.
Aug 25, 2013 | 1989 Buick LeSabre
2001 Chevy Impala 3.8L. P0171 lean fuel code. We have replaced the MAF from a previous code. O2 sensors scan good, as does the fuel pump all within specs. Car is running like junk. 81K, Dropped Cat...
DTC P0171 - System Too Lean (Bank 1)
Basically this means that an oxygen sensor in bank 1 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1.
Note: This DTC is very similar to P0174, and in fact your vehicle may show both codes at the same time.
According woth your previous tasks, inspect all vacuum and PCV hoses, replace if necessary.
Oct 04, 2011 | 2004 Chevrolet Impala
03 expedition, recently purchased, was told heater needed work, heater was working but when someone switched the control from hot to cool I cannot get the heat to come back on. I was told by the previous...
I think the previous owner needs some heat--inspec system-the vacuum controls on the panel cud hav issues or the heater door or the core itself--get a repair manual from fixya or a parts place
Jan 17, 2011 | 2003 Ford Expedition
Acer launch is stuck in a loop after system reboot- acer extensa 5620z windows vista
Something that is supposed to launch at startup is corrupted. Try booting in Safe Mode - if you can then disable all programs (including security ones) and try again. If now it works you know that it's one of them - enable them one by one till it fails again. If it doesn't work then it's either one of the drivers or Windows itself. Best solution is to reinstall
Mar 02, 2010 | Acer Extensa 5620 Notebook PC
Ibm2366
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
DVD drive not working with iTunes
Use system restore ,,, to restore your computer to a previous date before you downloaded itunes
click start ,, then in the search box type restore
Click Use system restore to restore system to a previous date (its the last one in a blue link)
follow on screen instructions, ensure the date you choose , is at least 1 day before you downloaded itunes.. BTW VISTA HAS MAJOR ISSUES
Jan 11, 2008 | Computers & Internet
Apple 24" iMac Desktop Logo
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
