On my new build asus board when fitted turning power on you get a code error beeep beepbeep and nothing on screen or keyboard / mouse tried taking everything off except ddr/power/and screen still nothing
    President:
  • 548 Answers
Remove DDR and see if it does the same thing. When you hear 3 beeps it is either VGA card or DDR. If you have a kit of two, interchange them and use different slots if you have the optionality.
If you need further assistance, just leave a comment
Posted on May 16, 2010
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
Motherboard DP35DP Installation Problem
You should try a regular ps/2 mouse and keyboard.  You probably don't have the USB drivers installed for the new board.  After you get booted into windows you'll be able to install those.
Oct 12, 2007 | Intel Motherboard
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
I toasted my school laptop, using it to seach arourd while taking break from studying and i am sure i now have a lovley viirus. while trying to restart laptop, all i get is the black screen with cursor...
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset.
If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Apr 19, 2011 | Computers & Internet
When i turn my dell on it jus beeps my mouse, keyboard & screen are off. also a,b ,c,d lights on
Did some checking. The mouse,keyboard and screen get there power the motherboard and the a:drive b:drive c:drive d:drive get there power from the power supply. The mother board gets it power from the power supply. So the problem is in the mother board. You can try to remove the battery for a minute and put it back with it unplugged of course to reset the Bios or jump the Bios pins on the board same thing.Check to make sure nothing is loose inside.Sometimes video and ram that get loose will make a computer beep and shut down and a bad stick of ram will to.
http://www.chuckstar.com/blog/technology/gadgematch-3-buy-a-new-pc-vs-build-your-own-system/.
Feb 12, 2011 | Dell Dimension 4700 PC Desktop
Hello How do I remove the keyboard from an Asus A6J A6000 entertainment notebook? Thankyou
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus A6J Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus A6J Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
4. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right. Power on your laptop and verify that the Asus A6J Keyboard is working.
Dec 11, 2010 | ASUS A6J Notebook
I also have a boot problem with this Mother board (asus p5vd2-vm)
Check for bent pins in the PS2 connector of both keyboard and Mouse jacks. Replace Keyboard with a working one, & The mouse too if possible and retry.............sodeep
Jun 07, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Will not boot with Keyboard and mouse plugged in
Did you try removing each memory module individually... Instead of just moving them around.. because the error you are receiving is a bad memory error code.
Jan 30, 2009 | ASUS P4P800-E Deluxe Motherboard
Motherboard detects nothing
anniegms, I had the same problem with a new Asus board running a Dual Core Duo Quad processor. The boards BIOS was not updated to handle the Dual Core Duo yet. I had to switch processors to a P4. Use a different PC to make a BIOS update disk. Update the BIOS and switch processors back. But I had all the same symptoms of yours. However I did/do have a PCI-E XFX Fatality (Nvida) based graphics card. I would check or swap processors, it sounds like the board is waking up but not the processor. Just my thoughts.... PCdok
Oct 21, 2007 | ASUS P5GD1-VM Motherboard
Open Questions:
Computers & Internet Logo
David Payne
David Payne
