Question about Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine
My 2.4 ghz cordless will not charge, they were pluge in 20 hours.
Could the batteries be dad
    President:
  • 2,030 Answers
Could be the batteries or could be they wall adapter
Posted on May 16, 2010
My Uniden Power Mac 5.8 GHZ w/ 3 phones have short talk time. If I change batteries, will it make my talk time longer. I kept of changing phones from one room to another when i hear beeping for low batt.
Have they always gas short talk time? If they are AA batteries you can replace with rechargeable NiMH with as high milliamp hours as you can get 2400+ these have much more staying power. They should charge ok but sometimes these can upset the charge unit.
Jan 15, 2013 | Uniden 5.8GHz Cordless Phone
Deleted handset by mistake how do I re register it. your problem?
You can try removing the battery from the deleted phone. Then put the phone into the main charging unit, the one with the answering machine, for a little bit. Reinstall the battery and put in the main unit again. Let it charge a few hours and try it again. Hopefully it will renegotiate it's status and be recognized by the master again.
Aug 29, 2012 | AT&T E2717B 2.4 GHz Twin Cordless Phone
My AT&T E5921 5.8 GHz - Cordless Phone handset shows "Connecting". I have tried 2 new batteries and resetting the base station as per the instruction manual without success. The charging...
I don't know if you have tried this but clearing all handsets from the base (so there are non) finish setting it for non and then start over as per manual.
Before you start re-setting them -
!st, unplug (for 20 seconds) then re-plug in Batteries from all hand sets. You may want to unplug the main Base as well at the same time you do the others.
My system has had problems that just unplugging and re-plug in the battery has solved. (It was flashing like someone was on it but if I picked it up there was a dial tone)
Hope this works for you :-)
Sep 08, 2017 | AT&T E5921 5.8 GHz - Cordless Phone
5.8 GHz GE CORDLESS PHONE is still flashing after being on the charge base for 12 hours
the battery is bad and needs to be replace.
the battery has three poles: one ground and two plus
the middle connector is wired with a small thermistor or diode to the plus connector. and this part is bad (open contact), so it will not signal to the phone print board to start the charging proces.
Aug 26, 2010 | GE 25932 Cordless Phone
Phone want hold charge long,what to do? i have a ge 25952ee1 5.8 ghz cordless
Remove the battery, wipe the phone contacts and battery contacts with a dry cloth, then reinsert the batteries and check to see if the charge lasts longer. If there's no improvement, it's time for new batteries.
Jan 03, 2010 | GE 25952EE1 Cordless Phone
My cordless phone fell in water. I have dried it and used it to make a call successfully once. It then prompted me with a message to charge the battery. After the phone sat on the charger it began to...
Usually ,phones don`t survive in water. But the best shot is to remove battery from the phone,dry the battery compartment with kitchen towel and battery.
Now leave it in a warm room for 24 hours(NOT on a RADIATOR, reconnect and fingers crossed for you !
Dec 27, 2009 | Panasonic KX-TG5651S 5.8 GHz 1-Line...
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
No dial tone or characters on hand phone,Phone charged for 12 hours.could battery be bad
this company sucks I call it and it just has automated features and hangs up where is the real customer service...
Jul 03, 2008 | Xact Communication Xact XG2400 2.4 Ghz...
Low battery
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at amazon.com or eBay.
Jun 22, 2008 | Vtech 9009111 Cordless Phone
Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine Logo
27 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
