Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheem 21vp50-1 pressure valve draining hot water constantly. It is 15 years old.
    Sergeant:
    Champion:
  • 333 Answers
Valve is bad boy a new one and install
Posted on May 16, 2010
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
We have a 15 year old Rheem "SK 1261" which recently has developed a steady and constant hot water drip from the hot water over flow. Initially it was a slow and inconsisent drip but now it...
If you are paying for your water, I litre per hour is going to cost you. If the unit is 15 years old, I would seroiusly comsider replacing it buy, if it's just a bad valve, you could try to replace it. If it is cracked at the threads, it's time to replace it for sure.
Dave
Jun 24, 2011 | Rheem Water Heaters
I replaced a 15 year old Rheem 40 gallon electric water heater with the same - a Rheem heater. After I replaced the old one, I was surprised that there was hardly any sediment build-up at the bottom of the...
These are interior metals, similar like rock used in a sauna, to help keep water hot longer. Here is somethings to check out.
Hello, dave
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Dec 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem Steller natural gas hot water service. There is a continuous dribble of water from the pressure valve overflow, even when the heater is not heating. I have tried easing the valve a few...
Yes, Turn the knob on the gas valve to off. Turn off the incoming water line into the water heater. If you have a valve on the outlet turn it off too. Open the drain at the bottom of the heater to drain a little water from heater. You can then lift the lever on the temperature/pressusre relief valve to let a little air in to release the vacuum and let the tank drain. If the relief is in the side let it drain a bit longer so the water level is below the outlet. Be sure to re-install the down pipe on the relief valve on the new valve. You should drain the a few gallons of water at least once a year from your heater, and you should exercise your temperature relief valve once a year to be sure it will function. If your new valve leaks suspect your temperature control allowing the water to get too hot.
Oct 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water dripping out of drain line on my Rheem Water Heater
The T & P valve is connected to the drain and it may be bad causing it to drip. You could try lifting the lever and then closing it back on it to see if it will seal. Also check the thermostat for heat setting, but than likely it is going bad.
It is a pressure relief valve and normally last about 5 years or more before they need to be replaced. The purpose of this valve is to protect heater from building up pressure and protecting the home, It releases water once the heater reachs beyond the limit of the valve can handle.
It is a standard 3/4" thread and can be removed with a pipe wrench. Just turn power, water off and drain water down to just below where the drain is.
Lowes or Home depot shoul dhave one just ask for a pressure relief vakve for a Hot Water Heater. prices range around $15.00.
May 31, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Dripping Drain valve on rheem water heater
If your water heater is 10 years old or more, it's much better to replace the entire thing before you start having additional problems with it. You MAY be able to drain your water heater and replace the valve with something more reliable, but, as I've said... if your water heater is old, this is just the 1st thing to go wrong. More will follow.
Aug 16, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Feb 10, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
167 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
