Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
  • 167 Answers
Usually when the high limit is tripping it is because of a element shorted to ground. The problem can be diagonsed with an ohm meter and replacing the defective element should solve the problem.
Posted on Jun 08, 2010
  • 349 Answers
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
Posted on May 16, 2010
Replaced both elements and both therostats still no hot water?
Have you checked your fuses or breakers, do you have power to the water heater?
Jul 15, 2014 | Water Heaters
Electric wh high temp shut off button keeps resetting
Water heater has upper and lower elements. Only one t-stat. Check to see where tstat is set to. Turn down to lowest level. If breaker still resets then replace tstat. It is letting the water get to hot no matter what setting it's on. So water is getting so hot that it trips breaker.
Dec 28, 2012 | Water Heaters
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
Aug 23, 2012 | Water Heaters
I replaced the heating element in my GE Smart Water electric water heater but still no hot water?
Does it have a reset on control ..check breaker .. use a volt meter on high setting check power at element work your way back find where power stoppes..
Apr 21, 2011 | General Electric Water Heaters
My hot water will not get hot at all. Model SE40M12AA01 Stop getting hot over night. Breaker to heater was tripped, I reset it and still no hot water.
Your upper thermostat on the hot water tank may be shorting out causing your breaker to trip. Remove the outer panel door on the side of the hot water tank and test for power going to the elements. Also check for water as the tank may be leaking and causing the short
Feb 21, 2010 | General Electric GE SmartWater Household...
We changed the therostat and it still kicks the reset button?
Sound like the heating elements are shorting out. Need to replace them after draininbg the tank. First shut off the breaker. Be safe and good luck
Apr 23, 2009 | Water Heaters
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
No hot water.
Please get an expert in - this is either the breaker is faulty or you have an electric fault int he boiler. You can try and replace the breaker - but match the current rating. But this could be dangerous if you keep trying to reset.
Jan 25, 2009 | Rheem Tankless Hot Water Heater...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
127 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
