Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
PanasonicNov 15, 2012 - Owner's Manual. Digital Video Camera. Model No. HC-V10. HC-V10M. HC-V11M ... You have purchased one of the most sophisticated and ...
PanasonicOperating Instruction Manual ( Multi ) - HCV10. FAQsFrequently asked questions about your product. What should I do if my product needs service? ... How am I able to turn off the time and date display on my camcorder? ..... LENS (ILC) POINT AND SHOOT DIGITAL CAMCORDERS LENSES ACCESSORIES · HOME HOME ...
Basic Operating Instructions Digital Video Camera HC-V10 Model No. Before use, please read these instructions completely. More detailed instructions on the ...
Remove neg batt cable. Drain the cooling system. Remove radiator cap, set heater control to max heat. Drain coolant through valve on bottom rad of the radiator. 12 qt bucket. Pull the carpet out of the way on the driver side floor. Remove the bolts to the steering shaft coupler cover. Remove brake light switch from bracket. Diconnect the power brake booster pushrod. Place towels underneath around area for fluid drippings. Remove retaining clips from HC fittings. Pull the tube out of the HC & carefully rotate them out of the way, plug the open tubes for less mess. Remove the HC bracket bolts, then remove the braket. Push the brake pedal down , the gas pedal up & move the shaft cover out of the way. Pull the HC out of the heat/ac hopusing unit...
