Question about Pool & Spa
How do you wire a 220 volt switch? - Pool & Spa
  • 8,404 Answers
LINE goes to the top two screws (one on either side), LOAD go to the bottom two screws ... ground to the switch frame and ot the box, if metal. LINE is from the panel; LOAD is to the motor.
Posted on May 16, 2010
Wiring diegram
should come wired for 220 volts one of the hot wires and the other colored or black wire should get 220 between them from each to ground 120 volts 1st hot to L1 2nd hot to L2 green to ground or case
Feb 10, 2018 | Smith Pool & Spa
P1353ME Intermatic Pool Timer starts and then stops
sounds like you are working with 220 2 blue are two hots across the two you should get 220 volts each of the greens and green should only give you 120 volts make sure unit can be wired 220 volts
Jul 05, 2015 | Intermatic P1353ME Timer, 3-Circuit Pool &...
How to wire a 220 volt switch
Turn off the main breaker controlling the power to the home. This will ensure that the wires at the 220-volt switch are not powered before working on them
Remove the cover from the old 220-volt switch with your straight screwdriver. Also, remove the screws that are holding the switch into the box. Pull the switch and wires out of the box so that the connections are accessible.
Identify the two sets of wires in the switch box, a red and a black pair, in the same conduit or insulated sheath. You should be able to see which wires are going to the device, or load. The line side is the other set of wires coming from the breaker.
Loosen the screws that hold the wires onto the switch. Pull all of the wires off of the old switch. Inspect the new 220-volt switch and identify the connection screws marked line and load.
Strip 3/4-inch of insulation from the ends of all four wires if they aren't already. Curl the tips of the stripped wires. Wrap the curled ends clockwise around the screws so that tightening the screw makes the wires wrap tighter.
Connect the black and red hot wires, or line, to the side of the switch marked "Line," usually the darker set of screws. Connect the two wires that are going to the device, or load, to the two screws marked as "Load" on the switch, usually the lighter colored screws on the switch.
Connect the bare ground wire, if there is one, to the green grounding screw on the switch. Push the wires and switch into the electrical box. Install the two screws that hold the switch into the box. Replace the switch cover and turn the main breaker back on.
Read more : http://www.ehow.com/how_8270481_hook-up-220volt-switch.html
Dec 13, 2014 | Electrical Supplies
Free wiring schematics
You didn't say what type compressor you have and didn't say what voltage.
A 220 volt compressor should use a double pole switch .
A 120 volt compressor only needs a single pole switch'
how to wire pressure switch for compressor YouTube
Aug 24, 2014 | Air Tools & Compressors
Hayward super pump wired to switch diagram
sounds like 220 volt if using a switch must be for 220 volts usually pumps wired for 220 volt blue wire to one side of switch terminals then new wire to pump L1 lug the other side of switch gets the red wire going to other side and new wire to pump from switch to L2 and green to case or ground make sure motor is wired for 220 volt on back
Dec 06, 2017 | Pool & Spa
Single phase motor 220 convert to110v; do you have switch wire inside the motor
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
Feb 26, 2012 | Delta Table Saw Tool Base 50279 Band Saw...
I recently purchased a Delta 50-760 Dust Collector and was told I could convert the motor to 220 volt. I presently have a 220 volt saw and wanted to run them both on 220 so I looked at the book and it said...
I am currently in the process of doing the same thing. Look at the inside cover of the switch case. This is where the capacitor is housed and is attached to the motor. On the inside cover there is a wire schematic. Not a very good one. I have yet to fully trace out the current wire connections. Don't forget to change your plug. You do not need to replace the switch, just rewire input power to the motor.
Jan 13, 2011 | Delta 50 - 760 1.5HP Dust Collector
JUST PURCHASED A RELIENCE 602 ELECTRIC HOT WATER HEATER 50 GALLONS TO INSTALL IN MY HOME WHAT GAUGE WIRE AND BREAKER DO I NEED TO INSTALL
The hot water heater should come with an amperage rating on it.
They vary from 30 to 40 amps, and then 10 or 8 gauge wire.
(All hot water heaters are 220 volt.)
I believe the 602 uses a 4500 watt element.
Divide 4500 by 220, and you get about 20 amps.
If you want to be on the safe side, you go with the heavier wire, 8 gauge, and then go with the smaller breaker that is more easily tripped, 30 amps. That way you can switch to a 40 amp breaker in the future, without having to change the wiring. The goal is to always make sure the wire is rated higher than the breaker. You want you breaker to trip before your wire melts.
But technically a 30 amp breaker and 10 gauge wire would be fine for this heater.
And since it is 220 volt, you will always use a double breaker.
That is because 220 volt appliances don't use a ground, but instead use the potential between to power wires that are 180 degrees out of phase. AC always does a sine wave, and the 2 power leads coming into the house are always out of phase. When one is 110 volts up, the other is down. So the total between them is 220 volts. And the way they intentionally zigzag the breaker box, 2 breakers next to each other always are on opposite power lines.
If you have any doubts at all about 220 and water heater wiring, please ask again. Wiring is not hard, but you have to understand what you are doing, or else you can cause serious consequences.
For example, if you use wire nuts or wrap wire around a screw, you need to always turn them clockwise, so they pull the wire when tightened.
You also always need to ground the chassis with a green safety wire.
Since a 220 hot water heater uses 2 power wires and a safety ground, the white wire should be striped with a permanent marker, so that it is not confused with the white neutral wire of a 110 volt appliance.
Aug 19, 2010 | RELIANCE ELECTRIC WATER HEATER
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
What size amp switch do I need.
NO! Use a switch rated higher in amps and equal to or higher in voltage relative to the breaker rating. Use a 40 or 60 amp switch rated a minimum 220 volts.
Feb 26, 2009 | Connecticut Electric 40 Amp 2 Pole Circuit...
Pool & Spa Logo
97 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
