Question about Route 66 Mobile 7 GPS Receiver
I tried to download the new version of route 66 from the internet but my current route 66 would not now open up as a programme on my phone. I don't know what to do...I went to shops and tried to get it fixed but they failed to nderstand the problem ...Can you please help.
I have Route 66 symbian series 60 (2005)- and would like to update my mobile benelux 128 mb multi media card-my cellphone is a NOKIA 6600 where can I find this update plse
Posted on Jun 09, 2010
HOW DO I GET A MANUAL FOR RAC 515F SAT NAV
ROUTE 66 - RAC satellite navigation devices
tw2.ro.66.com/rac/index.php?cid=UK
RAC Sat Nav 515F ... If your RAC Sat Nav develops a fault in the first instance contact the RAC Sat Nav ... If you have any questions about using your RAC Sat Nav please call on 01302 ... ROUTE 66 Navigate 7 - User manual - SW (499KB). ROUTE 66 RAC satellite navigation devices
It offers a PDF to download or read online.
Dec 10, 2014 | GPS
Tip
I BOUGHT MYSELF A FORTIS GPS NAVIGATOR AND IT CAME WITH THE ROUTE 66 SOFTWARE...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Mar 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Google chrome crashes everytime i open a website i want to fix it but i do not know how to have tryed a few thing i searched up they did not work
When all the suggested solutions don't work - try completely uninstalling and then reinstalling from a new downloaded file - not the one you used to install this current version (assuming you saved the download the first time). That should get you working again.
Jun 24, 2011 | Google Chrome
I got the VR3 gps with back-up camera less than a month ago, the first day it worked perfectly fine, then when I installed the route 66 stuff it started showing me some really long message saying to...
Ok so this happened to my gps after an improper shut down. Here is how I fixed it. Follow each step carefully and make sure your gps is fully charged before beginning.
1st open up the route 66 disk to see files not actually accessing the program. Right click on the disk and tell it to open from my computer. you will see many files one folder will say memoryimage.
2 Then on the gps click on settings and go to backlight setting backlight to the dimmest stetting. Now go into power and tell your gps to never standby.
3 Plug your gps into your computer then turn it on. Windows mobile will come up click on connect without setting up your device. Under file management click on browse contents of your device. You will now see what is actually on your gps. Open NANDFlash.
4 Now select all items except the route66 folder in the memoryimage folder of the disk and move them into the NANDFlash folder of your gps. When it asks how to transfer tell it to replace current folders with the same name. It will then take several hours to transfer.
5 On mine the route 66 exe file would not transfer back into the actual route 66 folder so I created a new folder then transferred the route 66 exe file from the route 66 folder in memoryimage of the disk into my new folder in NANDFlash. Once it is transferred you should be able to click navigation on the gps and have your gps load route 66. Your maps will be locked.
6. I kind of forgot how I did the next step because I cannot get back to where I was because I have already activated my gps. Go into the main menu from inside route 66 and either enter the extras folder or route 66 settings. Somewhere in one of these you will find a place to activate your route 66. It will then give you a website and an id for your gps. Go to the website and enter your gps id and the code from the voucher code card which came with your gps. Once entered on the website you will receive an activation code which you will have to enter into your gps. I recommend you turn off your gps then turn it back on and give it time to find you. You can go into gps status to watch for a signal and once you have a good signal it may take several minutes to locate you. After it has found you it should be working fine.
Aug 06, 2010 | GPS
I have recently purchased used powermatic 66 Table
That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
Oct 24, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
How to use Route 66 GPS set-up in nokia 6210 phone. Have tried many times with no success. Very annoying. ta Bill
I think Route 66 was used in Navigator 6110 Navigator only and it was linked with phones IMEI code. The 6210 Navigator is equipped with Nokia Maps 2.0 and Route 66 isn't compatible I think.
Oct 21, 2009 | Nokia 6210 Navigator Cell Phone
Route 66 stuck on the welcome screen (Route 66)
Get the update for Mini/Maxi route 66 from 183 Mb. Install this with card reader on the the SD card.
Then ,having the same problem, Route 66 will start up as usual.
Jan 11, 2009 | Route 66 MINI Handheld GPS Receiver
Gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Jan 07, 2009 | Route 66 MAXI Car GPS Receiver
Route 66 Mobile 8 Windows Mobile - software update creates error
To upgrade, use the website version of Route 66 Sync rather than the version on the disk or the upgrade file from the website, both of which do not work. The website version works in conjunction with Microsoft ActiveSync.
Dec 27, 2008 | Route 66 ROUTE EUROPE 2004 (601184407502)...
Activating Route 66 maps on my new Omnia
Gents,
It is quite simple
1. make sure you omnia is connected to the internedt
after insalling the route 66, go to
2. route 66 main menu
3. click on extras
4. scroll down and click on update
it will download and update
5 exit and go to extras again
6. now click on MAPs, you will find that Indi map would be seen as unlocked. select and enjoy
I have used many other gps maps in India but find that route 66 for India to be most accurate among them. but please note I was told that THIS IS AVAILABLE ONLY FOR 6 MONTHS ONLY. hope some one lets us know how to extend this.
Cheers
Raj
Nov 10, 2008 | Cell Phones
Route 66 Mobile 7 GPS Receiver Logo
245 people viewed this question
Top Route 66 GPS Experts
Craig Butler
Craig Butler
Will Halftowaite
Tom Chichester
Are you a Route 66 GPS Expert? Answer questions, earn points and help others
