Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
My foot controlled trolling motor pedal is slipping when turning
I'm not sure if something broke inside the shaft but the response of the motor changing direction has become increasingly worse. The motor barely changes direction eventhough the pedal is rotated from front to back.
  • rodhamilton2
    rodhamilton2 May 25, 2012
    I have one doing the same thing!!!
  • rodhamilton2
    Did you get it repaired? if so, what was the problem, I have one doing the same thing
  • 24 Answers
Mine did the same thing. It turns out that the bottom half of the shaft threads into the top half. So facing down toward the motor spin it counterclockwise while holding the small gear at the top of the shaft and it will tighten. Next you will have to adjust the cable slider gear. With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
    Problem Solver:
  • 6 Answers
Your cable may have broken or slipped and maybe bending rather than shifting in the sleeve. You may also want to check and make sure all set screws and cable locks are secure.
Posted on May 18, 2010
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
How are adjustments made to make the steering less sensitive ?
On the front side of the foot pedal is a large Phillips head screw. Tighten a little. It puts more pressure on the cable. Don't turn more than 1/4 turn at a time.
Jul 04, 2014 | Minn Kota Edge 45 Freshwater Bow Mount...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
876 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
ken skalski
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
