Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
Sch c300 calls not coming through
I think my child has barred all incoming calls to my phone and am trying to reset all the functions but it keeps asking for a password which I have never changed and the user manual for this phone is about as good as looking at the local bus timetable. I can still ring out and receive sms as well as send. Can you help me.
Sounds like call fowarding has been set try deactivation cfw feature / default codes are usualloy 0000 1234 12345 etc refer to your user manual or online service provider info
Posted on Jun 22, 2008
6ya staff
SOURCE:
Incoming calls disabled in calls barring asks for password never used one. How do I enable again?
I would take your phone to the Apple Store or try the factory reset.
Mar 22, 2016 | Cell Phones
Can't make outgoing calls - At & T
Since you have tried resetting the phone and checked that you haven't barred calls (call your operator to make sure that your line is indeed not barring incoming calls). The only thing you can do now, is to take the phone to a service center (or any place that has the right flashing equipment)to get the firmware flashed.
Dec 21, 2007 | LG Prada KE850 Cellular Phone
I created a password on my phone to be able to use call barring and now i have forgotten my password
since you tried everything, the best solution would be doing a factory reset on yout Sony Xperia phone.. but you have to backup your files on a computer first. To reset it, follow the ff steps below:
  1. Make sure the battery is not empty, better fully charge
  2. Turn on SONY XPERIA MIRO (ST23i/ST23a) smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA MIRO (ST23i/ST23a)
  6. The SONY XPERIA MIRO (ST23i/ST23a) will continue the step until ready to use in clean factory default.
Mar 05, 2014 | Sony Xperia miro ST23i Smartphone -...
My phone won't let any incoming calls come to my phone and
try to factory reset on your phone go to setting & tools option there click on phone setting then security then restore phone
for this you have to enter password which is last four digit of your number if you haven't changed it try it and let me no
hey better take a backup before doing reset
Nov 08, 2013 | Samsung SCH U350 Smooth - Blue Verizon...
I forgotten my phone barring password That's why has been Blocking my incoming outgoing call. How can i solve that problem. please kindly help me. Thanks
What is your mobile and model ?
If you forgot the security code you have to reset you mobile....... Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means just visit here Unlocking4u.com for the master reset code service and get the reset code........
Apr 05, 2012 | Cell Phones
How to bar my incoming call
just go to settings then select security settings... then select call barring services...select incoming calls only.. take note that when you select incoming calls and barred it you cannot also recieved sms or mms... ok... then activate it and it will ask for barring password.. a 4 digit password.. just put the default password 1234... ok... enjoy...
Aug 29, 2011 | Nokia N72 Cellular Phone
Call barring password for Nokia 2730
Hi,call barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
Jul 18, 2011 | Nokia Cell Phones
Please help mo to anblocked my call barring password.. i forgot my password and now it is blocked. :(
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
Jun 17, 2011 | Nokia C3 Cell Phone
The incoming calls whilw roaming is barred and no-one seems to know what code was used. Tried all the usual 111, 0000 etc. Help
Hi, Go to Call Setting, then go to Call barring, you will a outgoing calls,incoming calls, activate all, cancel all & Change barring password. choose the "cancel all" then the call barring password is 0000. if still the same maybe someone change your barring password. try to talk to your friends to know who made it.
Apr 25, 2011 | Cell Phones
When trying to restrict all incoming calls it asks for the password. I tried 0000 but it said "all in coming command error". Is there a stsandard password that is preset on the phone?
Normally that's the default password or 1234, but if none of them works, probably it means that your number profile hasn't incoming calls barring service active, this is done at the cellular central office switch, if this is the case, you should request to your cell phone provider the activation of incoming calls barring service (technically called BAIC) at your cell number number profile.
Feb 21, 2011 | Computers & Internet
Open Questions:
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
157 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
