Question about Lexmark Z600 InkJet Printer
Poor print quality
I am away for long periods of time and my printer suffers from lack of continus use. Is there some way to physically clean the print heads?
  • Official Brand Answer
  • 3,344 Answers
Here's a link to the Lexmark website to guide you on how to manually clean the cartridge nozzles and contacts. http://bit.ly/9wzuAL. Hope this helps.
Posted on May 17, 2010
The yellow ink will not print. There is definitely ink in the cartridge. I have tried the cleaning process 4 times.
  1. Print a Print Quality Check Sheet.
    1. Press the Ink or Ink Management button.
    2. Press the up or down arrow key to choose Test Print. Press OK.
    3. Press the up or down arrow key to choose Print Quality. Press OK.
    4. Press Color(Colour) Start.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  1. The LCD asks you if the print quality is OK for black and the three colors. Choose No.
  2. The LCD asks you if you want to start cleaning. Choose Yes. The machine starts cleaning the print head.
  3. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
  4. Repeat the cleaning and the quality check process following the Step 7-9.
  5. Compare the second or third Print Quality Check Sheet with the first one you printed in Step 1:
    1. Press Stop/Exit.
Note We do not recommend frequent unplugging and re-plugging of the machine and/or leaving the machine unplugged for extended periods of time.
  • To maintain premium print quality, our product is designed to automatically clean the print head periodically. When the machine is unplugged, it will not complete the periodic cleanings needed to ensure ink does not dry in the print head and may cause poor print quality.
  • Machines with a Message Center or Fax Preview have a 24 hour memory backup. All other machines have a 1 hour memory backup. If a machine is unplugged beyond the memory capability, the clock data is lost and causes the machine to reset. When the machine is plugged back into the outlet, the internal clock resets and the machine will automatically start a cleaning process causing the consumption of ink.
We recommend using the On/Off or Power Save button to power down the machine. Using the On/Off or Power Save button allows minimal power to the machine ensuring periodic cleanings of the print head occur only when necessary and needed information remains in memory.
Caution
  • Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
  • DO NOT touch the print head. Touching the print head may cause permanent damage and may void the print head's warranty.
  • Brother strongly recommends that you do not refill the ink cartridges provided with your machine. We also strongly recommend that you continue to use only Genuine Brother Brand replacement ink cartridges. Use or attempted use of potentially incompatible ink and/or cartridges in the Brother machine may cause damage to the machine and/or may result in unsatisfactory print quality. Our warranty coverage does not apply to any problem that is caused by the use of unauthorized third party ink and/or cartridges. To protect your investment and obtain premium performance from the Brother machine, we strongly recommend the use of Genuine Brother Supplies.
    > Brother Genuine Supplies information
Oct 28, 2010 | Brother MFC-5890CN All-In-One InkJet...
Poor print quality
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | HP Photosmart Premium C309A All-In-One...
Poor print quality
Clean the print head again .......
Sep 07, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I am having poor quality with black cartridge and printing. lines of text are barely visible or not at all. New printer cartridge (black). have cleaned and calibrated twice.
Cold be a fualty print head I would have to be there physically to see tho, try buying a printer maintence kit from a print supply store that should shore this problem up.
Jul 18, 2009 | HP PhotoSmart 7660 InkJet Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
I have a Dell 946 printer that is a couple of years old. It has started printing crooked on the pages. I have done the alighnment and that did not fix the problem. Can you help?
probably no much you can do the correct the problem because The problems that users encounter while using a Dell printer
varies with the model. However the common problems all Dell printer models suffer from are their slow speed and faulty paper feed mechanism. Quality of prints varies from one model to another, but most of the models do not produce prints having very fine qualities. A Dell printer is particularly notorious for its poor and faulty feed mechanism. They tend to cripple the papers or take in large number of papers at a time and print parts of documents on each page. They keep on generating messages indicating lack of paper, no matter the paper is being supplied or not. Such a problem makes the printer absolutely useless
Nov 20, 2008 | Dell 946 All-In-One InkJet Printer
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP Laserjet 4350dtn Print Quality poor
Most likely the fuser has lost part of the teflon from the heat roller. Having said that, the first step in any print quality issues is to change the toner cartridge. good luck!
Aug 26, 2008 | HP LaserJet 4350dtn Printer
Lexmark Z600 InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
