Question about Trendware TEW-435BRM (tew435brm) Wireless Router
I have a14 firmware. I reseted router, and now I can't connect to wi-fi, it need's security key. Where can i find it?
  • Harleen Nash May 17, 2010
    1. Please provide name of the router and the wifi card you have. There is not enough information here to assist you further.
2 Suggested Answers
smeago1
  • 136 Answers
SOURCE: laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Posted on Jan 03, 2008
Where do I find the IP adress so I may connect manually.
https://wwwimg.roku.com/static/oldlib/roku_player_documents/rokuplayerug.pdf
page 23 change network settings
then page 14 on wi fi settings
if new service provider gave you the encyrption key and has dhcp on then this should start Roku working on Wi FI.
New service provider would have installed a wi fi router this is most likely on 192.168.0.1 or 10.0.0.1 go to cmd prompt type in
ipconfig
then press enter key
Not the default ip address
the router should have a wi fi security option that tells you if the wi fi is encrypted and what ssid is being broadcasted.
DCHP should be enabled Roku will use this to assign itself an ip address once connected to Wi FI.
you need to know routers admin user name and password as well
Apr 18, 2016 | Roku 1
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
MAC Book Pro unable to connect the wi-fi. Connection timed out er
Reset your wireless password/key. Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 12, 2010 | D-Link Xtreme N DIR-655 Wireless Router
How to set up dlink wireless router withot the cd
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Nov 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cant connect to wifi
Please tell what is your Wi-Fi LED status. what channel count you configured inside the configuration of router. Please be sure that your wi-fi signal is transmitting or the device is able to receive the wi-fi signal.And please tell what router you using as host and what device you using as receiver. Thanks for subscribing Fixya... All the best
Nov 15, 2009 | Computers & Internet
How do you setup the wireless router?
http://192.168.1.1
or
http://192.168.0.1
Enable DHCP .
Thanks.
Nov 09, 2009 | NetGear WGR614 Wireless Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Changing Wireless network password without resetting the router
For that access your router with
http://192.168.1.1
or http://192.168.0.1
if you cant able access it then reset it
Press RESET button for 10 seconds it is in back sid of router.
then access above link.
type user name "admin' and password as "admin' or blank or "password'
then go to wi fi security first configure your router as WEP then go to wi fi security in advancwed then set WEP key it is your password to connect wi fi .
Aug 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
Password
Ok... There are tree things you need to know about securing your WI-FI network.
1: Each computer needs to have "permision" to access your WI-FI network.
2: The "Passphrase" and the "Key" are not the same thing. The "Passphrase" doesn't always work. But the "Key" should. (MACs will need the "key")
3: Some WI-FI equipment is "too old" to use 128 bit WEP or WPA.
(I don't think this aplies to your problem)
Nov 22, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trendware TEW-435BRM (tew435brm) Wireless Router Logo
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
