Question about Zyxel P660HW-D1 Router
Router requires resetting with MAC PC
I have a IMac running OSX connected to the one LAN port of the P-660WH router. When I connect my Iphone or a PC wirelessly. the IMac PC looses its connection to the internet and some times hangs. Anything I can do to sort? Thanks, Howard
  • 481 Answers
My first suspicion is that you may be experiencing an ip address conflict. If your iPhone or PC is using the same IP address as your iMac, only one of them will be able to communicate (and possibly neither of them). This should occur only if one or more of these devices are using statically assigned IP addresses. Check the internet configurations for your devices and make sure they are all set to use dynamic (DHCP) addresses.
For reference, a manual for your product can be found online at P-660HW Series - Ultra High-Speed Wireless ADSL 2+ Gateway for ...
There are several models and versions of your product, and the manuals are different for each, so knowing the exact model and version of your unit would help in diagnosing this problem.
Posted on May 16, 2010
I have an GT704-WG Rev B; Firmware= 30.17.0 which is connected to my (Macintosh) iMac running OS 10.6.7. Until about 6 months ago my older laptop (Mac, iBook, PowerPC purchased in 2001) was able to use...
Turn the Verizon router off.
Turn the ActionTec router off.
Turn the Verizon router on, and wait until its pattern of lights settles-down to a steady pattern, i.e., fully rebooted.
Turn the ActionTec router on.
Turn the ActionTec router on, and wait until its pattern of lights settles-down to a steady pattern, i.e., fully rebooted.
Use an Ethernet cable to connect from one of the LAN ports on the ActionTec router to the network port on your iMac.
You should now have Internet access.
The next step is to start Safari on the Mac, and connect to the web-server "inside" the ActionTec router, e.g., try http://192.168.0.1 and http://192.168.1.1 and http://192.168.2.1
Login to the router, and run the Wireless Networking Setup Wizard, to configure the wireless adapter:
* SSID -- the name of your network
* encryption-level, e.g., use 'WPA' or 'WPA2'
* password for your SSID
Once you've done this, any of your wireless devices should be able to connect to that SSID, and gain Internet access.
Mar 28, 2011 | Actiontec (GT704WG) Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Connecting modem to WAN port then any lan port to computer provides no connection. straight from modem to comp is ok.
Make sure comp lan and wan are both activated, Make sure the ethernet cable from modem is plugged into the input slot and NOT 1,2,3,or 4
Then after all is connected, unplug main modem for 10 seconds, plug back in, then do the same with wireless router. 5 minutes later, you should be good to go.
You can access the software of you router by opening up an internet page, and type 192.168.1.1 and hit enter. It should bring you right straight to the router's firmware/software where you can change any settings if desired.
If it asks for username and password, the default is usually admin for both. (see owners manual to be exact)
Nov 16, 2009 | D-Link AirPlus DI-524 Wireless Router
Trying install belkin n150 router.setup router and cables as setup guide instructs.i run cd but programe will not find connection to router.i played with connections and it showes i use wan miniport...
Try the following:
1. Make sure your PC is connected to the router directly and the LAN ports are lighting up
2. Reset the router
3. Reset the network adapter on your PC (or just restart the PC)
This should ensure that you are connecting on the LAN port.
Oct 09, 2009 | Belkin (F5D5231-4) Router
Router Question
hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Aug 29, 2008 | Linksys Wireless-N WRT150N Router
IMAC 660H Router Wlan
Have you tried connecting to the router using an ethernet cable? this will allow you to set the router up, which in turn will allow wireless connectivity
Jan 29, 2008 | Zyxel Prestige 660H Router
Can this be used with a MAC?
Any router will work, TCP/IP is a network standard, definately double check the cables. Your DSL modem is usually 192.168.254.254. and the router is usually 192.168.1.1. Check your documentation for the default IP. Once you know it type it in to the broswer in your Mac. Before doing so connect with an ethernet cable, purchase a new one if necessary. Connect from the <--> labeled port on the mac, or ethernet port. These wires are not like phone lines, they have 8 wires instead of 4/6. The router usually has ports on the back labeled 1, 2, 3, 4, and WAN. the 1-4 ports are LAN and that is also labeled on there. Plug the mac into port 1 and any other computers in after you get internet. once the physical connection is recognized. Go to your browser in the mac and proceed. if you get a web based router configuration page your router is working, then make the WAN connection to the ethernet port on the back of the dsl mode. Be sure your cables are good. Also go to your control panel and make sure your internet is enabled in your network section.
Jan 06, 2008 | Siemens SpeedStream 2624 Router...
Connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
Dec 08, 2006 | Kingston EtheRx Networking Switch
Zyxel P660HW-D1 Router Logo
141 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
