Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Top section not cleaning
The top section leaves particles on glassware and dishes after every wash.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues. Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded. To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure. For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump. Low water fills are a very common trouble maker with today's dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 16, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Will not clean dishes, leaves food particles baked on, leaves film on glassware. I use both cascade complete and Lemishine. Model# MDB7609AWW3
I had similar symtoms, my problem was that not enough water was reaching the dishes. As others have suggested, check the spray arm for cleanliness and freedom of movement.
Sep 12, 2011 | Maytag Dishwasher
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 | Dishwashers
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    Whirlpool Built-in dishwasher Model DU8700XB -O
    Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
    It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
    Mar 22, 2010 | Dishwashers
    Glassware is cloudy
    The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
    Nov 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
    When the wash cycle is done, the dishes are wet
    It seems that the newer dishwashers are worse at drying dishes than their tupperware melting predecessors were. They have all been tuned down, and do dry less. The only thing that you can do is to set your machine for the hottest wash, power dry and use a rinse agent that provides a sheeting action. Some folks use white vinegar as a supplement to their rinse aid, which has the added bonus of killing mold. Water also stays attached if the water has laid down minerals as noted by cloudy glassware. If this is the case, a dishwasher filter (dishwasherfilter.com, $70) might help. We try to wash hot, with a power dry and use a rinse aid/vinegar. Then, when the cycle is complete, but the dishes are still hot, we open the dishwasher, and "jiggle" the racks to get the excess water off of the glasses, and leave the dishwasher open about 2" at the top, so the dishes will continue to air dry. This has been an effective method for us.
    Best regards, --W/D--
    Aug 03, 2009 | Siemens Dishwashers
    Dishwasher is leaving food particles everywhere
    Clean the filter screen at the bottom of the washer basin.
    Apr 14, 2017 | Dishwashers
    Redeposits material on dishes
    We had the same problem and we have managed to resolve it for the most part.  We have found that the detergent makes a huge difference.  Our experimentation found that Cascade Complete powder did the best job.  Also, our old glassware was wide at the bottom and narrow at the top which I suspect made it difficult for the spray arm to get water up there so we bought new glassware and that helped a lot too.  It still happens from time to time but it is pretty rare.
    Oct 12, 2007 | Maytag 24 in. MDB5600A Jetclean II...
    KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
    54 people viewed this question
    Top KitchenAid Dishwashers Experts
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
