Question about Maytag 24 in. MDBH970AWS Built-in Dishwasher
I have maytag dishwasher leaves food residue
I have maytag dishwasher mdbh970aws 5 years old
It does not clean properly - leaves food particles on dishes
If dishes are NOT completely rinsed - they must be rewashed
    Champion:
  • 208 Answers
Check the inlet hoses; if the catch screens have sediment build up, that will reduce the pressure of the rinse water. Also, look for missing plugs on the rinse arms...
Posted on Apr 06, 2015
    Sergeant:
    Champion:
  • 333 Answers
There is a filter on the inside bottom of the dishwasher check and clean it
Posted on May 16, 2010
  • Brenda Reiber
    Brenda Reiber Nov 06, 2014
    how do you check it. do i have to take the machine apart?
I have a kenmore elite dishwasher model 665. it is several years old, and within the last year, it leaves food particles in glasses, etc... i tried different detergents and switched back and forth...
There should be a filter in the bottom under the spray arm. There should be 4 to 8 screws to remove to get to the filter, and clean.
Jan 27, 2013 | Dishwashers
Soap (?) residue on dishes; also not getting them clean--food on
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
After cleaning, our dishes have a cloudy appearance and a residue is evident. It's most evident on glasses, which have an opaque appearance. We haven't changed how were washing them or the amount/type of...
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jun 23, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
My 6 year old Kenmore Elite DW has started leaking and has a musty smell. The dishes are clean but food residue is left on the inside door and black gunk builds up on the bottom of the dishwasher.
Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
Mar 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Food residue on all dishes
The filter systems on the Maytag line of dishwashers which includes Jenn Air is very fine. In most causes the pump needs to be torn down and washed in a sink and a shop vac is also a great tool I use to clean the rest of the pump out that will actually stay in the dishwasher. The spray arms also need to be cleaned in the sink. Check your drain line under your sink as well and make sure that the drain line coming from the dishwasher has a high arch or bend that is higher than the base of the sink. This will prevent sink water from backing up in the dishwasher which can be nasty. Also make sure to run your hot water to the sink before starting a cycle to assure hot fills and the water temp. is best if set at 130 degrees on your water heater instead of 120 or 125 degrees. I hope this is helpful. This kind of problem can be agrivating to solve at times. Scott (North Caolina)
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Fine particles of food/grit left at end of cycle
Open the door and check it with a level. If the dishwasher isn't perfectly level, turn its feet (behind cover at floor) until it is level. If the jet bars can be removed, take them off and rinse them out. Make sure they're engaging with the pump outlet properly. There may be a plastic bushing that the main wash arms rotate on. If this is worn, replace it. It will make a world of difference. Finally, make sure you're using enough detergent. I suggest the cheap powdered type. It seems to have the best cleaning ability. Finally, make sure the rinse aid dispenser is set to dispense enough.
Jan 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDBH970AWS Built-in Dishwasher Logo
976 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
